Mon, Jan 27, 7:58 AM CST
Subject: Dynamic Follical/Scalp Prop for David?
RnRWoman ( ) posted Wed, 09 April 2008 at 10:27 PM · edited Sun, 26 January 2025 at 5:24 PM
Hi,
Is there any freebie of a Dynamic Follical/Scalp prop for the Mil David figure available out there?
Any help appreciated! Thanks!
--RockNRollWoman
svdl ( ) posted Thu, 10 April 2008 at 3:10 AM
Theres no prop that I know of. On the other hand, you can easily make one yourself using Poser.
  • Load David, disable inverse kinematics and set him in zero pose. Make sure all BODY and hip translations/rotations are set at zero too.
  • Select David's head
  • Open the Grouping tool
  • Create a new group, called Skullcap. All David's polygons should be dark grey by now.
  • Add polygons to the skullcap group by clicking them. Remove polygons by Ctrl+clicking themI prefer to use lit wireframe display mode when using the grouping tool,
  • When you think that the red polygons represent a nice skullcap, click the "Create Prop" button. Give the prop a useful name, then quit the Grouping Tool.
  • The prop you just made is the selected object. Parent it to David's head. The "inherit bends" option can be useful, it's best to enable it.
There's your scullcap. Save it to the library for reuse.
My gallery   My freestuff
RnRWoman ( ) posted Thu, 10 April 2008 at 3:27 AM
That's too bad that there isn't a freebie one. :( But thanks for yoru reply and your instructions on how to make a scullcap. Much appreciated. :)
