Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
I would say 4.1 to 4.2 is a fix and mod update. She had some new morphs added and some geometry adjustments. The largest change is the way in which her morphs are loaded.
Essentially the same model with added features.
If you are concerned with clothing, anything from V4, 4.1, 4.2 should be fine.
Victoria 4.2 has most of her morphs in injectable form, whereas 4.1 had them included in the figure (so she was easier to use, but heavier on system resources). The additional morphs include one to make a passable male out of her. As Synpainter says, clothes and textures should work on either version. Some older V4.1 characters may not work since they don't inject the necessary morphs.
Quote - Victoria 4.2 has most of her morphs in injectable form, whereas 4.1 had them included in the figure (so she was easier to use, but heavier on system resources). The additional morphs include one to make a passable male out of her. As Synpainter says, clothes and textures should work on either version. Some older V4.1 characters may not work since they don't inject the necessary morphs.
So how do you inject them, and from where? I have her and cant find the place to get the INJ files for the entire body - or do you have to do each one separately?
Quote - In my case they're under Poser 7/Poses/DAZ Victoria 4/Morph injections. should be simillar for other veersions of Poser since DAZ won't let V4 be installed into the Downloads directory.
Basically the same...I think the inquiry was, what actually needed to be "injected" in order to morph Victoria 4.2 .
I am a little new at this and i was wanting to know what is the difference between the victoria 4.1 model and the victoria 4.2 model. Thanks.
