Mon, Feb 3, 7:55 AM CST
Subject: scenery tuts
TIRROCCIA ( ) posted Mon, 14 April 2008 at 1:03 PM · edited Sun, 02 February 2025 at 9:40 PM
How do i get all that cool scenery to look right? Do i resize my preview window befor loading, do i load and scale each peice? I've spent 1 hour looking for some kind of tut on this.
what's the trick? I've seen countless great images with awsome scenery and like lights(I so Suck) I can't seem to "get it"
HELPPPPPPPPPPPPPPPPPPPPPPPPP
Acadia ( ) posted Mon, 14 April 2008 at 1:22 PM
Can you give a link to an example of what you are referring too?
Is it a package that contains  actual scenery props, or are you talking about a background image?
pakled ( ) posted Mon, 14 April 2008 at 9:19 PM
Define 'right' - Bill Clinton...;)
What sort of scenery? There's landscape programs like Bryce 5.5 and Terragen, modeling programs like Wings, Blender, and Anim8tor, and some Poser-related items like Cyclorama.
Acadia will have the links...;)
TIRROCCIA ( ) posted Tue, 15 April 2008 at 3:55 PM
Sorry everyone ....I'm talking about the scenery like from DAZ, ,like for exsample..."Classic pool."or even Villa Venus entance. These type of scenery.
(I have poser 6, am a beginner.) Its the buildings that fustrate me. I'm sorry i wasn't clear.
svdl ( ) posted Tue, 15 April 2008 at 4:39 PM
For 3D scenery, you need several things.
  • A skydome. You don't want the default grey background color to show up in your render, do you? You can easily make a skydome yourself in Poser:
  • load a hires sphere prop;
  • scale it to 50,000 percent;
  • open the Grouping Tool and click "Reverse Normals". The large sphere will turn red;
  • close the Grouping Tool;
  • switch to the Material Room;
  • set the Ambient Color of the PoserSurface material to white, and the ambient value to 1;
  • drag your mouse from the Ambient Color input onto the background of the material editor window, accept the "New Node" option when you release the mouse button, choose 3D textures, then choose Clouds.
  • Do a quick render to check your skydome; you now should have a clouded blue sky.
Next, you need something for your figures,buildings, plants and trees to stand on. There's a lot of terrain props and figures out there, but I find that I always return to the Microcosm terrains (available at www.runtimedna.com) They are the most versatile and best quality terrains I know.
Building your scene/environment takes patience. Make use of the Aux camera to view the scene from different angles.
Lights: Tricky. A useful starting point for lighting an outdoor scene is
  • delete the default Poser lights;
  • create a new light. Set the color to white, intensity to 30-50%, and change the light type to IBL. You can turn on ambient occlusion too.
    This light is used to tune the general amount of light in the scene.
  • create another new light. Set the color to white, intensity to 100%. Change the light type to Infinite, then click "Advanced material properties" and set the diffuse color of the light to a very dark grey (maybe even black), keep the specular color at white.
    This light exists to create specular effects on materials that should have speculars, it does not "light" the scene in a normal sense.
You could create a third light that takes on the function of sunlight/moonlight. This light can either be infinite or a spotlight. Shadow strength should be less than 1 (0.4 to 0.7 are decent values), colors depend on the mood you want to set.
One important tip: scaling of architecture made for Poser is usually not needed. Move the camera or the prop/figure instead.
My gallery   My freestuff
TIRROCCIA ( ) posted Tue, 15 April 2008 at 10:48 PM
Thank You SOOOOOOOOOO much!
