I used to get that sometimes with Poser 5. Haven't gotten it at all with Poser 6 though.
Just click "OK", and see what your scene window shows up as. Then just set it to what you want again, and resave your preferences.
If I recall, sometimes the window was mini mini, and sometimes it was the same size, but way off the screen almost hidden behind the tool bar.
If that doesn't work, change your preferences to "factory settings", then close and reopen poser again. Then set up the interface the way you want and resave your settings again.
say." - Ghandi
Quote - 1. There is no window after trying to open files
- When I click OK Poser opens with no window at all
- If I change window size it makes no difference
Go to the Edit menu option and set your preferences to open at Factory Default.
Then close poser, and reopen it again. It should be the way it was initially installed.
Then set up the interface the way you want it again, then go back to your Edit menu and set your preferences to "preferred".
say." - Ghandi
