DAZ|Studio F.A.Q (Last Updated: 2024 Nov 18 2:47 am)
Solid black background and white for the transparency and then make sure you have that map plugged into the Opacity node and set it to 100%. Should work fine.
---Wolff On The Prowl---
If you set maximum transparency to something less than 100% in Poser than the item won't work as designed in D|S, because that goes from 0% opacity at the black end to a maximum opacity at white (so in effect the range is shifted so that it butts up against transparent instead of butting up against opaque in Poser). If that is your issue then you have two options - adjust the tones of the transparency map so that it covers the whole 0%-100% range in both application, or use the Layered Image Editor in D|S to add a white overlay to your transmap with the opacity set to the minimum value you want (so if your max trans in Poser was 80% you'd make the white layer 80% transparent).
The other monor issue is that you mustn't have transmaps applied to surfaces that are meant to be opaque - it's another side of the same thing, in Poser if the max transparency is 0% then the map has no effect while in D|S if the max opacity is 100% the map may cause the surfaces to be transparent if it isn't white.
Hello, I have made some textures for the Evening Style dress at Daz. I made them for Poser and they look well in it. I tried them in Daz and I can't get the transparency to work correctly. Are transparencies supposed to be made differently for Daz? Also, the dresses have a shiny effect that I can't get in Daz.
Any help is appreciated,
Sapphy
