Sat, Jan 11, 3:16 PM CST
Subject: is that ever happend to you?
kionde ( ) posted Sat, 03 May 2008 at 4:38 PM · edited Thu, 09 January 2025 at 4:09 AM
i have 1800 objects and 5.800000 polygons in that render. i had before also some small artefacts like 5 pieces, but now the number increased, so i cant repair it anymore with photoshop. it happens always in final mode, if i switch on the lens glare than they get big black holes. do anybody know why  this happens, and how to avoid it? click on pic.
Mazak ( ) posted Sat, 03 May 2008 at 5:12 PM
Do you have the latest update?
If your objects imported from Poser try this link
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2390404
and here another maybe helpful thread.
http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2727884
Mazak
Google+ Bodo Nittel
dlk30341 ( ) posted Sat, 03 May 2008 at 5:12 PM · edited Sat, 03 May 2008 at 5:20 PM
Yes, I have had this & for the life of me I can't find the thread at EON tech support where they replied to my question about this very thing(I hate the search function there).
Was the above items saved in V5/V5I by any chance?  I've only had this happen when I've used various items(not all) that I had saved as .vobs back in those days.  If I imported the item fresh as an OBJ/PZ3/3DS etc the problem disappeared.
Edit to add a pic & to note on this particular items the highlights were white & at 100% for all but 1 which had a green highlight.  This items was saved in V5I as a .vob
Dang I wish I could find EONS reply & I can't remember what they said either :(
gillbrooks ( ) posted Sat, 03 May 2008 at 5:44 PM
Ooh - I had this happen with Flinks Flowers.  I contacted Flink about it and we worked out that I was using vobs that I'd imported and saved in Vue 5.   I re imported the original obj files in Vue 6 and it cured the problem and they now render perfectly
Gill
Powertec ( ) posted Sat, 03 May 2008 at 6:23 PM
I had this happen once a while ago but don't remember what the fix was... Sorry...
Nice work though!
silverblade33 ( ) posted Sun, 04 May 2008 at 12:02 AM
Try adjusting the highlights, sometimes, it's the way highlights work
i.e. change slider for anisotropic highlights to the other end of scale :)
kionde ( ) posted Sun, 04 May 2008 at 4:20 AM · edited Sun, 04 May 2008 at 4:33 AM
***Quote - I've only had this happen when I've used various items(not all) that I had saved as .vobs back in those days.  If I imported the item fresh as an OBJ/PZ3/3DS etc the problem disappeared.
all items were 3ds and obj before. i stored them as vue vob files, and imported in that scene.
you mean that, if they stay original files than this problem doesent happen?
its also starange that i just had a few artefacts before, and the number rised up with the new objects i brought into. they are all converted into vob objects.
dlk30341 ( ) posted Sun, 04 May 2008 at 9:18 AM
Just various ones saved in V5I - not all of them by any means.
Tried silverblades suggestion to no avail - thanks for the suggestion.  No big deal though can re-import.
silverblade33 ( ) posted Sun, 04 May 2008 at 1:50 PM
well, when I had that problem, it was a specific material that caused it, in that case, a wooden plank material (texture based)
checkthegate ( ) posted Sun, 04 May 2008 at 2:10 PM
great image...might try rendering separate layer passes? ...background...foreground...midground...AO ...diffuse...etc....
kionde ( ) posted Sun, 04 May 2008 at 3:35 PM
in my render it seems to be the glow material on several light emitting surfaces. if i switch out the glow, i get less artefacts, but they dont disappair.
we do it for this: www.banthapoodoo.de
croxie ( ) posted Mon, 05 May 2008 at 2:53 AM
I've had this happen as well, with a freshly upgraded Vue 6 xStream, and it is due to certain materials.
I suggest that you start taking a closer look at the procedural materials you have in your render and replace them if possible.
In my case, I had to replace every single material and then still do the render in sections to avoid the black dots from appearing.
Hope this helps and good luck :)
C.
"Keep smiling, it makes people wonder what you're up to."
kionde ( ) posted Tue, 06 May 2008 at 4:39 PM
thanks for nthe answers
