Sat, Jan 4, 1:40 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 29 10:47 pm)
Carrara Free Stuff here.
Subject: "carrara 6 Pro is not installed"= HUH?
jackhalsey ( ) posted Tue, 29 April 2008 at 3:39 PM · edited Wed, 01 January 2025 at 8:13 AM
I downloaded and ran the carrara update 6.1.1 with no problem.
I downloaded the 6.1.2 update and it loaded and asked for my language and then said "Carrara 6 pro is not installed on this computer."  I tried it again, running as administrator with no results?
Carrara Pro 6 is installed and works so any ideas?
Thank you.
Hoofdcommissaris ( ) posted Tue, 29 April 2008 at 3:46 PM
 I have had this happening, sort of. That happened after I renamed Carrara.
Did you do that? The installer is not too intelligent in that department...
MarkBremmer ( ) posted Tue, 29 April 2008 at 3:52 PM
 This will also happen if you try to install the Render Node instead of the actual Pro application on the same computer.
MarkBremmer ( ) posted Tue, 29 April 2008 at 4:26 PM
 Make sure that you take a look at page 432 in the Carrara manual also.
jackhalsey ( ) posted Tue, 29 April 2008 at 6:01 PM
Mark
You might have misposted as page 432 refers to anything glows.
Thank you both for your help.  But still no go.
MarkBremmer ( ) posted Tue, 29 April 2008 at 6:07 PM
 Ha! Thought I was in another thread when I posted this - smart guy... ;)
MatrixWorkz ( ) posted Thu, 01 May 2008 at 10:14 AM
That's what happens when they make idiot proof installers that won't let you browse to your install directory. :tt2:
My Freebies
jackhalsey ( ) posted Thu, 01 May 2008 at 12:24 PM
Matrix
I agree I still cant install it.
LostinSpaceman ( ) posted Thu, 01 May 2008 at 3:09 PM · edited Thu, 01 May 2008 at 3:14 PM
Have you tried renaming it to the old directory name and  then renaming it back to whatever it is you have now? Or, if you have it in the proper directory, have you tried reinstalling Carrara 6 Pro base and THEN installing the 6.1.2 update? Just a thought.
charlesatlas ( ) posted Fri, 02 May 2008 at 4:39 PM
Lost
I havent renamed carrara so I will try reinstalling Carrara 6 base.  Thank you.
LostinSpaceman ( ) posted Sun, 04 May 2008 at 9:13 PM
Did it help? The only reason I ask is sometimes installers are programmed to look for the original install and won't recognise upgraded installs. Lousy programing I know, but i've run into it before.
jackhalsey ( ) posted Mon, 05 May 2008 at 12:59 PM
I tried it but I reinstalled it and then did the first update and same problem with the second.  Should I reinstall it and just jump to the second update?  Amazing they dont have an option to manually set path.
LostinSpaceman ( ) posted Mon, 05 May 2008 at 10:22 PM
that was kind of my point of reinstalling the base and then the latest update. You shouldn't need the first update as it would obviously be in the second update already.
jackhalsey ( ) posted Thu, 08 May 2008 at 12:11 PM
okay will try that althought it would have been easier if they would have included a way to manually point the way to the correct path.
Thank you.
MatrixWorkz ( ) posted Thu, 08 May 2008 at 6:02 PM
I totally agree with you there!
My Freebies
mgatch ( ) posted Wed, 14 May 2008 at 10:57 AM
Are you using the right patch? I just had the same problem with the 6.2 patch. It seems I inadvertantly downloaded the patch for C6 Standard instead of the Pro version.
jackhalsey ( ) posted Wed, 14 May 2008 at 11:12 AM
Thank you but it was the right patch....must just be my machine but even that doesnt make sense.
sparrownightmare ( ) posted Mon, 02 June 2008 at 9:26 AM
I has that with the 6.1.2 installer, and I have C6 installed into the default directory.  I fo not have the render node on this box either so I just think it's a wonky installer.  I ended up waiting to patch from 6.1.1 until the 6.2 patch came out.  That one worked fine.
