Wed, Dec 25, 12:46 PM CST
Subject: Question
Stan57 ( ) posted Wed, 14 May 2008 at 10:33 PM · edited Wed, 25 December 2024 at 12:45 PM
I would like to make a body morph and then be able to save it so i can export the whole body  to hexagon. I have tryed to save it as an obj file but that doesnt work so i am doing something wrong.
Thanks in advance
Stan
Jack Of All Trades Master Of None
Morkonan ( ) posted Wed, 14 May 2008 at 11:02 PM
Quote - I would like to make a body morph and then be able to save it so i can export the whole body  to hexagon. I have tryed to save it as an obj file but that doesnt work so i am doing something wrong.
Thanks in advance
Stan
What is "not working" for you on exporting it as an object?  Can you load it in Hex, does it appear corrupted or something like that?
geep ( ) posted Wed, 14 May 2008 at 11:05 PM · edited Wed, 14 May 2008 at 11:07 PM
Hi Stan,
Are you checking "As a morph target" when you export?
Do NOT check "As a morph target..." because this removes all your morph deltas.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Stan57 ( ) posted Thu, 15 May 2008 at 12:55 AM
Ah ok,thats what it was. I have no idea how i did that i dont normaly mess with the buttons but i guess i did
Thanks for the help!!
Stan
geep ( ) posted Thu, 15 May 2008 at 2:34 AM · edited Thu, 15 May 2008 at 2:35 AM
You're quite welcome ... It's my pleasure.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley ( ) posted Thu, 15 May 2008 at 2:19 PM · edited Thu, 15 May 2008 at 2:20 PM
Quote:
"Are you checking "As a morph target" when you export?
Do NOT check "As a morph target..." because this removes all your morph deltas."
 "As a morph target..." does NOT remove deltas. I fact I recommend that you do use "As a morph target..." when exporting, as what it does exclude from the obj is the effect of any transforms (rotate, translate, scale, taper). The other option you should use is "Include existing groups...".
Stan57 ( ) posted Thu, 15 May 2008 at 2:28 PM
Quote - Quote:
I will give it try ,thanks
