Quote - I would like to make a body morph and then be able to save it so i can export the whole body to hexagon. I have tryed to save it as an obj file but that doesnt work so i am doing something wrong.
Thanks in advance
Stan
What is "not working" for you on exporting it as an object? Can you load it in Hex, does it appear corrupted or something like that?
Quote:
"Are you checking "As a morph target" when you export?
Do NOT check "As a morph target..." because this removes all your morph deltas."
"As a morph target..." does NOT remove deltas. I fact I recommend that you do use "As a morph target..." when exporting, as what it does exclude from the obj is the effect of any transforms (rotate, translate, scale, taper). The other option you should use is "Include existing groups...".
Quote - Quote:
I will give it try ,thanks
Jack Of All Trades Master Of None
Thanks in advance
Stan
