Fri, Jan 24, 8:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: small problem.
smalll ( ) posted Thu, 15 May 2008 at 8:54 AM · edited Thu, 23 January 2025 at 3:55 PM
Hi. I need your help.
You know Business Man P4 Lo who in Figures > Poser 1-4 > Poser 4 Lo
(I used poser 5)
I like him because he is small size.
But, I found aproblem.
I applied pose to him, he turned ugly.
How can I fix him?
Can you help me?
Please.
nimos100 ( ) posted Thu, 15 May 2008 at 9:14 AM
Dont use the model a lot my self so might be wrong.
However it could be that the pose you use werent made for that character and when it tries to pose it, it mess it up.
If you know that the pose normally work with that character it might be the joint settings that you have somehow changed.
So you could try to open the joint editor and see if the hip joint is affecting the mesh correctly.
smalll ( ) posted Thu, 15 May 2008 at 9:30 AM
Thanks nimos100.
I want to know that you say.
Can you tell me more
detaily?
How....?
Please.
geep ( ) posted Thu, 15 May 2008 at 9:31 AM
Either that or .............. he has some sort of medical problem .............. LOL. :lol:
Sorry, couldn't resist ... my bad ...... bad geep, bad !
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Thu, 15 May 2008 at 9:47 AM
Hi geep.
We feel highly honored by your concern.
nimos100 ( ) posted Thu, 15 May 2008 at 9:52 AM · edited Thu, 15 May 2008 at 9:53 AM
Quote - Thanks nimos100.
detaily?
How....?
Please.
A quick test you can make is to try to just pose the character manuel, try to move him into some "extreme" poses, but still maintain some reality to it. An idea could be to move his legs so it looks like the pose you are trying to use, doesnt have to look exactly like it, just close to it. Then you can see if you get the same problems as before, if thats the case its most likely the joint settings that are wrong, if you dont have any problems its most likely because the pose werent made for that character.
If its the joint editor then let me know and ill try to explain it to you. As it can be a little confusing, if you havent used it before :)
smalll ( ) posted Thu, 15 May 2008 at 9:54 AM
I will try.
Thank you.
Acadia ( ) posted Thu, 15 May 2008 at 10:03 AM
How can I fix him?
Can you help me?
Please.
Was the pose you used made for the P4 man? Or was it made for another figure?
It could be the pose was meant for a different figure and that is why it is causing problems with the pants.
Can you use another P4 figure? One that doesn't have any clothes on it from the start, and try that same pose and see if it works?
If the pose works on a nude P4 figure, then the problem is with the P4 Business Man. It might be the "Lo Res"  part causing the problem.
In that case is there a P4 Lo Res nude figure that you can use and put your own clothing on him?
I know you speak Korean, and I tried to translate all of that into Korean using Babel Fish, but I don't seem to have the language font because all that showed up were a bunch of question mark symbols.
Gareee ( ) posted Thu, 15 May 2008 at 10:15 AM
I just think he's VERY well endowed...(snicker!)
Maybe he has one of those Japanese tentacle monsters in his pants?
geep ( ) posted Thu, 15 May 2008 at 10:17 AM
Uh oh, me thinks me just got upstaged by Gareee.
@Smalll ... I am highly honored that you are highly honored .......... please no offense was meant. ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Thu, 15 May 2008 at 10:20 AM
You right **Acadia.
I used poser 4 Hi > Business Man
It dose not work correctly.
Thank you very much!**
markschum ( ) posted Thu, 15 May 2008 at 10:57 AM
I would try a magnet to move the pants back where they belong.
lesbentley ( ) posted Thu, 15 May 2008 at 12:20 PM
I agree with markschum, use a magnet.
It's just an old, and not very well designed figure. You will probably never fix it completely, but you could use a magnet to pull the polygons in the crotch up a bit, that would help.
lesbentley ( ) posted Thu, 15 May 2008 at 12:39 PM
Try this. Select the figures hip. Create a magnet (from the menu bar, Object > Create Magnet). Copy the text of the pose file below, and paste it into a text editor (Notepad will do). Save it to a pose folder as "CrotchFix.pz2". This will set the magnet the same way as was used in the image in my last post. If you wanted you could spawn a morph from the magnet, then delete the magnet from the figure. But a magnet is more flexible than a morph, so you may prefer to lock and hide the magnet, then save the figure back to the pallet with the magnet attached. The magnet is only  for when the lags are spread, in normal poses turn the "Mag 1" dial in the hip to zero. Here is the pose for the magnet:
//CrotchFix.pz2
version
        number 4.01
baseProp Mag Base 1:2
        channels
                rotateY yRotate
                        keys
                                k  0  0
                rotateX xRotate
                        keys
                                k  0  0
                rotateZ zRotate
                        keys
                                k  0  0
                translateX xTran
                        keys
                                k  0  0
                translateY yTran
                        keys
                                k  0  0.323642
                translateZ zTran
                        keys
                                k  0  -0.0101435
        deformerProp Mag  1:2
magnetDeformerProp Mag  1:2
        channels
                rotateY yRotate
                        keys
                                k  0  0
                rotateX xRotate
                        keys
                                k  0  0
                rotateZ zRotate
                        keys
                                k  0  0
                translateX xTran
                        keys
                                k  0  0
                translateY yTran
                        keys
                                k  0  0.606
                translateZ zTran
                        keys
                                k  0  0
sphereZoneProp Mag Zone 1:2
        channels
                rotateY yRotate
                        keys
                                k  0  0
                rotateX xRotate
                        keys
                                k  0  -0.00105191
                rotateZ zRotate
                        keys
                                k  0  -0.771484
                translateX xTran
                        keys
                                k  0  0
                translateY yTran
                        keys
                                k  0  0.326835
                translateZ zTran
                        keys
                                k  0  -0.0101435
        buildSphere
        newFalloffCurve
        falloffCpt 0 1
        falloffCpt 0.2 0.93
        falloffCpt 0.8 0.07
        falloffCpt 1 0
        endFalloffCurve
figure
lesbentley ( ) posted Thu, 15 May 2008 at 12:59 PM · edited Thu, 15 May 2008 at 1:11 PM
P.S. If thre crotch still does not look right in the fighting pose, try moving the Mag Zone up a bit, say to yTran 0.353 Poser Native Units. A little xTran may also help.
smalll ( ) posted Thu, 15 May 2008 at 4:38 PM
 I can´t find the words to thank you.
Your kindness really moved me.
I am so much obliged to you for your kindness.
