Mon, Nov 18, 1:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 8:56 pm)
Subject: several parts Mat pose?
trades2cash ( ) posted Thu, 15 May 2008 at 3:01 PM · edited Mon, 30 September 2024 at 7:20 AM
I have a prop that is made of several different moving objects. Each object uses the same material. Is there a way to create a single mat pose that will apply the material to all parts of the prop? Thanks for any help.
Conniekat8 ( ) posted Thu, 15 May 2008 at 5:04 PM
If all the parts are from one prop, then you can save it as a mat collection, then turn that mat collection into a mat pose.
If there is more then one prop, I don't know how to handle it.
lesbentley ( ) posted Thu, 15 May 2008 at 8:47 PM
Quote:
"I have a prop that is made of several different moving objects. Each object uses the same material. Is there a way to create a single mat pose that will apply the material to all parts of the prop? Thanks for any help."
If the props are not parented to a figure, then I don't think it can be done. If the props are parented to a figure then it should be possible, as long as only one instance of the pp2 needs to be loaded in the scene. But I don't think Poser could make an mc6 for it, I think you would have to construct the Mat pose by hand. Perhaps MAT Pose Edit could do it, I'm not sure.
trades2cash ( ) posted Fri, 16 May 2008 at 4:03 AM
thanks for the information everyone. I was not sure.
