Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 30 3:32 am)
If all the parts are from one prop, then you can save it as a mat collection, then turn that mat collection into a mat pose.
If there is more then one prop, I don't know how to handle it.
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Quote:
"I have a prop that is made of several different moving objects. Each object uses the same material. Is there a way to create a single mat pose that will apply the material to all parts of the prop? Thanks for any help."
If the props are not parented to a figure, then I don't think it can be done. If the props are parented to a figure then it should be possible, as long as only one instance of the pp2 needs to be loaded in the scene. But I don't think Poser could make an mc6 for it, I think you would have to construct the Mat pose by hand. Perhaps MAT Pose Edit could do it, I'm not sure.
