Mon, Nov 25, 10:24 PM CST
Subject: Procedure entry point could not be located.
drawbridgep ( ) posted Fri, 16 May 2008 at 5:30 PM · edited Mon, 25 November 2024 at 10:21 PM
Oh my dear Brycers, yes I have forsaken thee and only come back here when I need something.
I ran Bryce 6 the other day and it did nothing.  Had an hour glass for a few seconds but Bryce refused to run.  no error, no message, no flowers, not even a card.
So I uninstalled and then reinstalled. It now gives the following:
Stupid error
Any ideas?
Thanks pals.
Phillip Drawbridge
Website
Facebook
TheBryster ( ) posted Fri, 16 May 2008 at 5:37 PM
Forum Moderator
Hi, Philip!
WB
Sounds like a corrupt installation. ;-)
drawbridgep ( ) posted Fri, 16 May 2008 at 5:40 PM
Was I gone?
and thanks.
Phillip Drawbridge
Website
Facebook
danamo ( ) posted Fri, 16 May 2008 at 5:48 PM
Hmmm, that looks like a D/S dll. I haven't upgraded to ver.6. Do you have DAZ Studio installed?
I was thinking that was unlikely since you have Carrara.
drawbridgep ( ) posted Fri, 16 May 2008 at 5:53 PM
I should have it since it worked in the past and doesn't B6 install it anyway?  Actually I've run D|S recently (outside of Bryce) so I could test a model out.
I might try and remove D|S and then try a reinstall.
Thanks.
Phillip Drawbridge
Website
Facebook
danamo ( ) posted Fri, 16 May 2008 at 5:58 PM
You're welcome Phil, and good luck.
drawbridgep ( ) posted Fri, 16 May 2008 at 6:08 PM
Aha!    It seems that my version of D|S was installed with my version of Bryce 6.1 whereas I'm having to install version 6. (At least for now)
I've now got it to work with an olderversion of D|S.
Phillip Drawbridge
Website
Facebook
bobbystahr ( ) posted Fri, 16 May 2008 at 9:11 PM
Good detective work...welcome back...heh heh heh.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
CrazyDawg ( ) posted Sat, 17 May 2008 at 4:21 AM · edited Sat, 17 May 2008 at 4:23 AM
Quote - Oh my dear Brycers, yes I have forsaken thee and only come back here when I need something.
Stupid error
Any ideas?
Thanks pals.
Ok, first question and possible answer for you.
Have you been using Carrara 5 or 6 since installing bryce 6.
If so unstall carrara and bryce, install bryce again and stay away from carrara and get your butt back here in this forum....we have sent out a bug that corrupts files on any computer that uses anything other than bryce by order of the all mighty cardinals..
All jokes aside, unistall bryce, remove all folders/files from ones computer, use a program that will look for clone or files in the reg that are no longer in use or needed by programs, may i suggest Advance window care personal(its free) once you have run it and corrected all issues needed doing re-install bryce and do a reboot, not needed but best to do after any installing of programs.
I have opinions of my own -- strong opinions -- but I don't always agree with them.
pakled ( ) posted Sun, 18 May 2008 at 9:39 AM
not to mention that D|S changes versions almost as fast as Wings does...;)
