Wed, Dec 4, 3:46 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: keeping track of multiple test renders?
lbjvg ( ) posted Sat, 17 May 2008 at 11:55 AM · edited Tue, 03 December 2024 at 2:45 PM
Hi - I am trying to get the perfect render for a scene using VUE 6 pro studio.  I found the sticky post about rendering options very helpful and have made multiple sequentially numbered renders  (render to disc) of the same scene.
Does anyone have any tips for a simple way of keeping track of what the render setting were for a particular render .bmp?  I indicate some of the major settings in the file name itself.  Ideally there might be some automatic way to "dump" the render setting to a .txt  file with the same name as the .bmp.
Thanks, Jim Gallagher
bruno021 ( ) posted Sat, 17 May 2008 at 12:56 PM
Render settings are found in the environment folder of your Vue application folder, they have the ".urs"  extention.
Can't you just save your own settings? Maybe it is Infinite & xStream only.
FrankT ( ) posted Sat, 17 May 2008 at 3:02 PM
you can only save render settings in infinite or XStream Bruno
My Freebies
Buy stuff on RedBubble
checkthegate ( ) posted Sat, 17 May 2008 at 4:26 PM
Also be very careful...,...too..if your flicking through sunsets...you might just pick one with an embedded radiosity...suddenly your scene jumps to 3 hour renders!
Peggy_Walters ( ) posted Sat, 17 May 2008 at 5:49 PM
Don't forget the render area!  You can render just a tiny portions of the file (say just a face, or a part that has lots of detail).  Then adjust your render settings.  No need to render the entire scene until you are pretty sure the settings will work.
LVS - Where Learning is Fun!
bruno021 ( ) posted Sat, 17 May 2008 at 5:58 PM
@ Frank, actually I meant that saving your render settings might be Infinite & xStrem only.
stormchaser ( ) posted Sat, 17 May 2008 at 10:00 PM
lbjvg - When doing test renders with different render settings I will name each picture test #1, test #2 etc. I will save each manual render settings with the same name so I know what's what.
