Thu, Jan 9, 11:52 AM CST
Subject: What program do you use to make morph object?
smalll ( ) posted Sun, 18 May 2008 at 8:32 AM · edited Thu, 09 January 2025 at 11:39 AM
Hi.
I want to make morph.
I want to apply mimic program to my model.
And I found that the best way to make morph is export figure's body.
But, obj file has many meshes.
It is hard to me to cotrol it.
What program do you use?
What is the best way?
Can you help me?
Please.
ockham ( ) posted Sun, 18 May 2008 at 8:52 AM · edited Sun, 18 May 2008 at 8:54 AM
It's best to export one body part at a time from Poser.
Load the figure into Poser.
On the menu: File:Export:Wavefront OBJ
A hierarchy list will pop up.
Check only the part you want to work on. (The Head, for example.)
Then, on the Export Options panel, check the "As Morph Target", no
other boxes.
Name the OBJ something like "HeadOnly.obj" to avoid confusion.
Import this OBJ into your modelling program, and move vertices to make the morph.
Save the result, for example "HeadOnlySmile.obj"
With the entire figure in Poser, select the head.
On the parameters box, click the "Properties" tab.
Hit the "Load Morph" button, and browse to your "HeadOnlySmile.obj"
Fill in the name blank, and you're done.
Resave the figure under a new name.
My python page
My ShareCG freebies
adp001 ( ) posted Sun, 18 May 2008 at 8:55 AM
Don't forget to check "as morphtarget".
pakled ( ) posted Sun, 18 May 2008 at 9:42 AM
Attached Link: Wings 3d
Wings 3d...Doc Geep has a tutorial for making the 2 work together. Plus, it's a modeler, so you can actually make props, clothing, and characters for Poser (eventually...characters are hard, no matter what the program...;)
adp001 ( ) posted Sun, 18 May 2008 at 9:58 AM
@smalll: If you're using P7, you may use Posers "morph brush" for a start.
geep ( ) posted Sun, 18 May 2008 at 11:10 AM · edited Sun, 18 May 2008 at 11:16 AM
Attached Link: "Makin' Morphs" Tutorial compliments of Dr Geep Studios
*(click the image to view full size) (**CLICK** the **LINK** above the image to view the tutorial - 19 pages)
Hi smalll,
This tutorial might help get you started.
Do not get frustrated and give up ... just keep trying and ... you'll get it.
Questions are always welcome.
When you are finished with this one ...
You might want to look at some of the other classes at Poser University.
They're FREE and there are over 100 from which to choose.
cheers,  ... and happy morphing ... :biggrin:
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Sun, 18 May 2008 at 7:13 PM
It was very kind of you to show me the way.
Thank Ladies and gentlemen!
It was a great help to me.
