Sat, Jan 11, 2:50 AM CST
Subject: Creating turbulence for airplane
coldk ( ) posted Tue, 20 May 2008 at 5:35 AM · edited Sat, 11 January 2025 at 12:02 AM
Hello,
Does anyone know of any tutorials or suggest how to create turbulence for an aircraft in vue?
many thanks
coldk
Trepz ( ) posted Tue, 20 May 2008 at 5:50 AM
turblulance? Do you mean the heat haze behind the aircraft? Do you mean the diplacement of air around the wing ? Are you animating and want the plane to shake?
"Many are willing to suffer for their art. Few are willing to learn to draw."
coldk ( ) posted Tue, 20 May 2008 at 5:52 AM
Hi,
Yep, i mean the displacement of air. Not animating, just a still image.
thanks
Trepz ( ) posted Tue, 20 May 2008 at 7:16 AM
I think the easiest way to do that would be in (insert paint program here) with a bit of smudge and or blurr...In Vue you would have to have an object the right shape and then a nice material simulating something like heat haze..which there was a discussion recently in the forum about.
Monsoon ( ) posted Tue, 20 May 2008 at 2:55 PM
I agree with Paul.....I would do that in post rather than struggle trying to achieve it in 3d. Most paint programs have ample distortion tools to take care of that. Photoshop's Liquify brush may be of service.....
coldk ( ) posted Wed, 21 May 2008 at 3:54 AM
Many thanks,
I'll try the Liquify brush - first have to learn a little how to use it!!!
many thanks again.
marren ( ) posted Wed, 21 May 2008 at 7:06 PM
http://www.renderosity.com/mod/freestuff/index.php?page=6
Sky trails by Spacebone
Just an idea
thundering1 ( ) posted Fri, 23 May 2008 at 8:27 PM
http://www.renderosity.com/mod/gallery/index.php?image_id=1056987
It's just easier and more flexible to do in post. The way I did the above image's air turbulance is copy the shot onto a new layer, use (if I remember right) Water Ripple filter, then turn that layer into an Overlay mode, adjusted the opacity, and masked (or you can just erase) everything but right below the ships.
Hope this helps-
-Lew ;-)
