..... or simply open Poser 7RuntimeLibrariesCharacterPoser 1-5Poser 2 LoCasual Man P2 Lo.cr2 in CR2Editor, select the hand and look for:-
alternateGeom rHand_2
name GetStringRes(1037,2)
objFile 2002 :Runtime:Geometries:maleHandsLo:rHandShape_2.obj
and in the hand channels:-
geomChan handGeom
uniqueInterp
name hand type
initValue 0
hidden 0
forceLimits 4
min 0
max 19
trackingScale 0.045
keys
static 0
k 0 0
interpStyleLocked 1
Use these lines as patterns for your figure.
Basically you have a series of 'alternateGeom' blocks defining the paths to the alternate geometry files, then a 'geomChan' channel to do the actual switching.
The 'usemtl' defined in the obj files need to have matching 'material' statements in the 'figure' section of the cr2.
Below is an example of geometry switching for the head. Attached above is the text of a working example. Note that the attached example uses a Poser box prop as the default head, loaded via "objFileGeom", so as not to need to distribute an obj file with this example. Normally the default geometry would be loaded by a "figureResFile" statement.
actor head:1
<span style="color:rgb(153,153,153);"> name head<br></br> on<br></br> bend 1<br></br> dynamicsLock 1<br></br> hidden 0<br></br> addToMenu 1<br></br> castsShadow 1<br></br> includeInDepthCue 1<br></br> useZBuffer 1<br></br> parent BODY:1<br></br> creaseAngle 80</span>
alternateGeom head_2
objFile 1002 :Runtime:Geometries:props:ball.obj
alternateGeom head_3
objFile 1003 :Runtime:Geometries:props:cone.obj
alternateGeom head_4
objFile 1004 :Runtime:Geometries:props:cylTex.obj
channels
geomChan HeadSwap
uniqueInterp
name New Head
initValue 0
hidden 0
forceLimits 4
min 0
max 4
trackingScale 0.045
keys
static 0
k 0 0
interpStyleLocked 1
The 'max' value in the 'geomChan' needs to be the number of geometries used including the default geometry. The syntax I have used differs a little from that used in the skeleton figure, in that it simplifies by leaving the 'name' lines out, but it works just as well.
Does anyone have or know of any tuts about geometry switching? Been trying all morning to find one but to no avail. Cant find anything in the manual either.
