Wed, Feb 26, 7:12 PM CST
Forum Moderators: RedPhantom
Subject: Geometry switching
Touchwood ( ) posted Wed, 21 May 2008 at 5:28 AM · edited Wed, 26 February 2025 at 4:07 PM
Does anyone have or know of any tuts about geometry switching? Been trying all morning to find one but to no avail. Cant find anything in the manual either.
vince3 ( ) posted Wed, 21 May 2008 at 5:59 AM · edited Wed, 21 May 2008 at 6:00 AM
i think  svdl knows, so you could ask him as he is asking in a thread he started just below yours whether to use that method for a package he is releasing.
thread is called "How to package"
icprncss2 ( ) posted Wed, 21 May 2008 at 6:56 AM
You might want to check out BL Render's Secrets of Figure Creation or PhilC's modelling tutorial.  Both of them go into geometry switching.
PhilC ( ) posted Wed, 21 May 2008 at 7:26 AM
..... or simply open Poser 7RuntimeLibrariesCharacterPoser 1-5Poser 2 LoCasual Man P2 Lo.cr2 in CR2Editor, select the hand and look for:-
 alternateGeom rHand_2
  name GetStringRes(1037,2)
  objFile 2002 :Runtime:Geometries:maleHandsLo:rHandShape_2.obj
and in the hand channels:-
  geomChan handGeom
   uniqueInterp
   name hand type
   initValue 0
   hidden 0
   forceLimits 4
   min 0
   max 19
   trackingScale 0.045
   keys
    static 0
    k 0  0
   interpStyleLocked 1
Use these lines as patterns for your figure.
lesbentley ( ) posted Wed, 21 May 2008 at 8:22 AM · edited Wed, 21 May 2008 at 8:34 AM
file_406563.TXT
You can find a good example of geometry switching in the hands of the Poser skelleton figures. These came with P4, and I expect they are still included in the Additional Figures folder if you have done a full install.
Basically you have a series of 'alternateGeom' blocks defining the paths to the alternate geometry files, then a 'geomChan' channel to do the actual switching.
The 'usemtl' defined in the obj files need to have matching 'material' statements in the 'figure' section of the cr2.
Below is an example of geometry switching for the head. Attached above is the text of a working example. Note that the attached example uses a Poser box prop as the default head, loaded via "objFileGeom", so as not to need to distribute an obj file with this example. Normally the default geometry would be loaded by a "figureResFile" statement.
actor head:1
<span style="color:rgb(153,153,153);">       name    head<br></br>      on<br></br>        bend 1<br></br>    dynamicsLock            1<br></br> hidden          0<br></br> addToMenu       1<br></br> castsShadow             1<br></br> includeInDepthCue               1<br></br> useZBuffer              1<br></br> parent BODY:1<br></br>     creaseAngle 80</span>
        alternateGeom    head_2
                objFile 1002 :Runtime:Geometries:props:ball.obj
        alternateGeom    head_3
                objFile 1003 :Runtime:Geometries:props:cone.obj
        alternateGeom    head_4
                objFile 1004 :Runtime:Geometries:props:cylTex.obj
        channels
                geomChan HeadSwap
                        uniqueInterp
                        name New Head
                        initValue 0
                        hidden 0
                        forceLimits 4
                        min 0
                        max 4
                        trackingScale 0.045
                        keys
                                static  0
                                k  0  0
                        interpStyleLocked 1
The 'max' value in the 'geomChan' needs to be the number of geometries used including the default geometry. The syntax I have used differs a little from that used in the skeleton figure, in that it simplifies by leaving the 'name' lines out, but it works just as well.
Touchwood ( ) posted Thu, 22 May 2008 at 1:24 AM
Thanks everybody. Off to play a while :-)
