Thu, Feb 13, 6:53 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 5:20 am)
Subject: How do you fix an opengl problem?
Darboshanski ( ) posted Wed, 21 May 2008 at 12:21 PM · edited Tue, 11 February 2025 at 7:14 PM
If one has an openGL problem in P7 how do ya fix it besides going into SreeD?
Thanks!
My Facebook Page
markschum ( ) posted Wed, 21 May 2008 at 12:34 PM
Poser 7 will work with the basic microsoft Opengl driver.  If your card driver is the problem try updating to the latest driver  or search the forum here for opengl driver . Some people seem to have better luck with a driver from about october 2007.
make sure you have loaded directx9 as well.
redtiger7 ( ) posted Wed, 21 May 2008 at 12:55 PM
I just looked this up (and can't find it now) but someone mentioned this:
Open up the Poser 7.ini file in notepad.
It can be found under documents and settings/(your profile name)/application data/Poser 7
Find teh line
PREVIEW_OGL_OBJECT_BBOXPICKING 0
and change the 0 on the end to a 1.
It may help, but I'm slowly getting teh feeling that the fault has to do with the ATI card and drivers themselves.
CuriousGeorge ( ) posted Wed, 21 May 2008 at 1:20 PM · edited Wed, 21 May 2008 at 1:21 PM
I feel your pain, I have an ati x1600.  I've heard about nvidia cards having probs with Posers opengl implementation as well.  However, I have yet to run into an opengl issue with cinema4d on my ati.  Take that with a grain of salt.
-CG
Darboshanski ( ) posted Wed, 21 May 2008 at 1:42 PM
I have a Nvidia card and poser is the only app I have with this issue. I have no problems in Vue.
My Facebook Page
jdcooke ( ) posted Wed, 21 May 2008 at 4:36 PM
OK, ATI/AMD have just released they're May Catalyst drivers. I've installed them and I'm getting a HUGE performance improvement with legacy OpenGL software like Poser 5, 7 and Wings3d. before this release only version 7.11 worked with these apps. good luck jdc
bopperthijs ( ) posted Wed, 21 May 2008 at 4:56 PM
I recently upgraded to vista64 ultimate and because my Saphire xl1550 (ATI) card didn't worked well with it  I replaced it with an asus EN8800GT (nvidia) card. The first week I had nothing but trouble with all my graphic programs: rhino, hexagon, poser, uvmapper even vue6 refused to run in the opengl hardware mode, I loaded the latest drivers but nothing worked until I uninstalled all the drivers and utilities like gameOSD and smartdoctor and did a fresh install with the original drivers and no utilities (I didn't buy it for games!) Before that I also used a program called driver cleaner which was mentioned in another thread, to remove all the old ATI drivers and registrykeys.
After that everything worked like a charm.
You can find driver cleaner here:
www.drivercleaner.net/
 But I can't garantee anything and you get a warning to be careful with program.
good luck.
Bopper.
Darboshanski ( ) posted Wed, 21 May 2008 at 6:10 PM
I am surprised that I'd have so much driver trouble given I have only had Nividia based cards installed on this machine. I could understand having trouble if I had ATI drivers once installed but I never have.
I hear mixed things about using a driver cleaner but they have been from those that may have not followed the directions I don't know I am always chicken when using utilities that screws with drivers. Since I also have a Nvidia chipset on my motherboard and I am afraid that this driver cleaner will remove those too. Can you isolate the display drivers from the motherboard drivers with this Driver Cleaner?
Thanks!
My Facebook Page
bopperthijs ( ) posted Thu, 22 May 2008 at 3:26 AM
I'm afraid I can tell you very much about this program, I just used it because I suspected there were some ATI-drivers left, you can specify the drivers in a searchlist, but if you didn't had any other cards installed before you nvidia card I don't recommend to use it. As you said: this program can screw up things. For me it was a last try to get rid of my problems, but I suspect that reinstalling the original drivers actually solved the problems.
Bopper.
Greebo ( ) posted Thu, 22 May 2008 at 10:21 AM
I haven't installed the new Nvidia drivers yet so I've no idea if they've solved the problem, I should really do that I guess. There was another thread around here that suggested creating a new profile for Poser in the card control panel and turning everything non essential off.
Worked for me :)
