Fri, Feb 14, 6:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 5:18 am)
Subject: What the bloodey hell am i doing wrong
dolly ( ) posted Tue, 19 June 2001 at 10:19 AM ยท edited Fri, 14 February 2025 at 6:26 AM
Hey all Ive been trying to make props for all to use ,now i make the prop in poser export it as 3ds as amapi dont cater for objs. Then i import to amapi muck about with it then save as 3ds,follow me good,right then i import it to poser size it to fit the head of the figure im working from ,then i export it as obj,open the uv-mapper and make a uv map. i save the map then i import the obj back into poser and fit to the figure when i try to put the texture on it dont work. All and any help will be much appreciated thanks in advance dolly
twillis ( ) posted Tue, 19 June 2001 at 10:35 AM
Dolly, in UVMapper, make sure that after you've remapped the texture and saved the texture map, that you save the model as well. The new mapping won't work with the old obj file. Like, say, you load a file into UVMapper called Prop.obj. You remap it in mapper, and save the texturemap as Prop.bmp. Then you have to use the save model command, and save the remapped model (either as Prop.obj, or under a new name, like Prop1.obj, that's up to you). Let me know if that doesn't solve your problem. --Terri
Wizzard ( ) posted Tue, 19 June 2001 at 10:36 AM
aaaaaaaaaaahhhhhhhhhhh.... sorry dolly I had to read it a few times 8 ) ye have to save the mapped obj as well.. so the mapping's with it.. so.. in steps.. you inport the object into uv mapper.... create the map... save the obj. [ either as uvobjname or objname] getting the mapping done up is great butif the obj doesn't have the information embedded 8 ) give it a go.. I think you'll be much pleased by the results the best of luck my friend 8 ) any questions.. that's what we're here for..
dolly ( ) posted Tue, 19 June 2001 at 10:41 AM
you two are top men thanks all thats one thing i did`nt do is save the model..der thanks again dolly
Wizzard ( ) posted Tue, 19 June 2001 at 10:45 AM
no probs mate... though ermmm Terri's a lovely lady 8 ) I'm the olde man 8 ) tis what we're all here for na? Cheers mate
dolly ( ) posted Tue, 19 June 2001 at 10:54 AM
oooopppsssss sorry about that still thanks anyway, oh and geuss what ti works i just tried it and gord blimey it works it was like a urika moment thanks to you all, Il start the props now and they will be up soon dolly
Wizzard ( ) posted Tue, 19 June 2001 at 10:59 AM
Good stuff Dolly!!! now about those vob's..... 8 ) you've made some fantastic Vue props and scenes... that'd be great as obj's or 3ds's.. noruch at all.. I have the vob versions.. and I'l ltry to export from vue as soon as I get it loaded 8 ) great work my friend.. thank you
dolly ( ) posted Tue, 19 June 2001 at 11:01 AM
ok mate i was just thinking the same thing i will try the fireplace first cheers dolly
Wizzard ( ) posted Tue, 19 June 2001 at 11:06 AM
twillis ( ) posted Tue, 19 June 2001 at 11:16 AM
Dolly, don't worry about the "der" on saving the model. How do you suppose I knew what the problem was? Because I'd had the same problem, of course! I know what you mean about the "Eureka" moment. It's so cool when all the parts come together (though I try to refrain from running through the streets naked, like ol' Archimedes did -- the neighbors tend to get rather put out). Looking forward to your props. And Wizzard, thank you for the "lovely lady". There are those who would take issue with either word! --Terri
