Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
The export works, but the max import doesn't work -- Autodesk doesn't keep it up to date -- there is a 3rd party importer, but that only works with certain versions of 3ds max. Check the official poser pro website for exact details -- the url escapes me right now....
There is a sample on the poser pro website showing that it works, but I haven't tried animation yet. You might want to post more details on exactly what you're trying to do, and see if anyone else has tried exactly what you want to do.
Poserfusion is part of PoserPro.
You use Poserfusion to import and render animations in MAX, you use Collada to import rigged characters to then rig and pose them in MAX.
What you need to use is Poserfusion, not Collada, for what you want to do.
Your specialist military, sci-fi, historical and real world site.
It is part of the package.
It is a plugin that allows you to pretty easily import Poser content into 3dsmax. It use to be called BodyStudio.
It also supports figure animation and dynamic cloth. Unlike Collada, you can't repose figures in Max. The plugin does maintain a dynamic link to the poser file so you can open the poser figure up in poser and adjust the pose etc. and save it and reopen the Max file and you will see your changes.
It won't install on Max 64bit - only 32.
Hi,
Can anyone tell me if the Collada animation import to Max p from PoserPro works.
cheerio lululee
