Wed, Jan 8, 11:22 AM CST
Subject: how do I get a 'wet look' using shaders
pj1240 ( ) posted Tue, 27 May 2008 at 4:24 AM · edited Tue, 07 January 2025 at 3:15 PM
I'm trying to do an alien figure in poser I've got a basic skin texture but I want to give it a wet look in poser. Rather than customising the texture in photoshop is there any way I could use the shader tree in poser to create this sort of look. I currently just modelling it at the moment.
I know there's the v4 wet skin shaders by skinvue but I don't really want to buy that just to see how the shading is done as I don't really need it for v4.
 It would be good if I could change the look using spectular lighting and thus get different effects. Also any ideas how to get a more slime like apperance as well for possible offspring?
 Any help gratefully recieved :o)
jonthecelt ( ) posted Tue, 27 May 2008 at 5:32 AM
Basically, the wet look is driven by the specular settings. The specular and specular colour settings control how much shine is shown; the specular nodes (glossy, anisotropic, and so on) control how the specular shine is calculated, and therefore it's final appearance on the model; and if you want a droplet feel to the wet look, then using one of the nodes such as spots or similar will break up the uniformity of the shine.
I'm loathe to give specifics, since every character and circumstance is diferent - there's no hard and fast rule as to what are the 'right' settings'. But those are the nodes you should play around with until you get the look you're wanting.
JonTheCelt
Acadia ( ) posted Tue, 27 May 2008 at 5:46 AM
Funny you should ask this. I posted the same question in the "Node Cult Forum" at RDNA a few hours ago.
http://www.runtimedna.com/mod/forum/messages.php?forum_id=92&ShowMessage=389923
pj1240 ( ) posted Tue, 27 May 2008 at 7:02 AM
thanks for that - I shall experiement with the specular settings
bagginsbill ( ) posted Tue, 27 May 2008 at 8:51 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3179186&ebot_calc_page#message_3179186
I'm at work and don't have time for a big post. :)
Follow the link for a quicky reference to get you started.
bagginsbill ( ) posted Tue, 27 May 2008 at 5:34 PM · edited Tue, 27 May 2008 at 5:34 PM
Progress. Like it? When I finish, I'll post it. Click for full size.
Anniebel ( ) posted Tue, 27 May 2008 at 6:34 PM
Quote - Progress. Like it? When I finish, I'll post it. Click for full size.
That looks really good.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Marque ( ) posted Wed, 28 May 2008 at 6:40 AM
So can you do just areas, like beads of sweat on the forehead?
Thanks
bagginsbill ( ) posted Wed, 28 May 2008 at 7:33 AM
Well I suppose you could, using a mask, but the way i'm doing it causes it to appear only if the surface is facing the light at the right angles. The shader is putting them on all the skin, but it appears to be strongest only in certain directions.
