Sun, Feb 9, 12:33 AM CST
Subject: hand held camera in vue?
Zak666Williams ( ) posted Fri, 30 May 2008 at 5:23 PM · edited Sun, 09 February 2025 at 12:22 AM
Dose anyone know a easy way of adding camera shakes for a hand held camera movemnent in vue? rather then maulay animating every shake with Key frames?
thanks.
stormchaser ( ) posted Fri, 30 May 2008 at 10:24 PM · edited Fri, 30 May 2008 at 10:25 PM
Is it not possible to constantly change views between two cameras, both very close together to simulate this movement?
Sorry, I know nothing of animation so please ignore my post if it was a stupid answer! :blink:
It's 4-25 in the morning & I need sleep......................
jeffg3 ( ) posted Sat, 31 May 2008 at 7:40 AM
What version are you using?
Mazak ( ) posted Sat, 31 May 2008 at 7:57 AM · edited Sat, 31 May 2008 at 7:59 AM
In Animation Wizard set a Vibration for your Camera. 5Hz frequency and 20 intensity will be a good starting point for your animation.
Mazak
Google+ Bodo Nittel
ajtooley ( ) posted Sun, 01 June 2008 at 8:30 AM · edited Sun, 01 June 2008 at 8:31 AM
A couple of months back I took a Poser figure, applied a BVH running motion, imported the figure into Vue, then linked the camera to his shoulder as if he were holding a large professional camera.
I only did one test this way and wasn't too impressed with the results, but it might have just been the motion file I was using. I haven't had time to try it with a different one.
Zak666Williams ( ) posted Mon, 02 June 2008 at 1:21 AM
Aswome! how do you link objects?
i've only realy played around with ladscapes in vue and importing poser figures for studio arts producs.
is it like grouping?
Zak
