Wed, Dec 4, 2:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 12:42 pm)
Subject: poser save problem
TheBob ( ) posted Sun, 01 June 2008 at 12:11 PM · edited Wed, 04 December 2024 at 2:13 PM
ok i am working on something in poser i save it like regular and when i go to open it..it loads then gives this, i am running vista ultimate and it opens other saves just not this one
markschum ( ) posted Sun, 01 June 2008 at 2:14 PM
can you click on the "view problem details" and post that screen ?
TheBob ( ) posted Sun, 01 June 2008 at 4:31 PM
it just closes if i do that it doesn't do anything
Jules53757 ( ) posted Sun, 01 June 2008 at 4:36 PM
Try to delete the libraryPrefs.xml. Sometimes it helps. Otherwise, did you change the Driverfor your graphics card?
If all doesn't help try an installation with minimum content over your existing Poser installation.
Ulli
TheBob ( ) posted Sun, 01 June 2008 at 6:00 PM
i dont have any file called "libraryPrefs.xml and i havnt made any changes to windows or anything..it just isnt working
TheBob ( ) posted Sun, 01 June 2008 at 9:21 PM
it says this in the problem signature
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    Poser.exe
  Application Version:    7.0.0.63
  Application Timestamp:    456b7bee
  Fault Module Name:    kernel32.dll
  Fault Module Version:    6.0.6000.16386
  Fault Module Timestamp:    4549bd80
  Exception Code:    c0000005
  Exception Offset:    000cbfd0
  OS Version:    6.0.6000.2.0.0.256.1
  Locale ID:    1033
  Additional Information 1:    98f6
  Additional Information 2:    87675ed52f92c29ca9743f9c4f847526
  Additional Information 3:    98f6
  Additional Information 4:    87675ed52f92c29ca9743f9c4f847526
kuroyume0161 ( ) posted Sun, 01 June 2008 at 9:31 PM
Quote - i dont have any file called "libraryPrefs.xml and i havnt made any changes to windows or anything..it just isnt working
Sure you do.  In Poser 7, they moved preference files to the Windows "Documents and Settings" user folder.  In Vista, this would be in the Users user folder.  Should be under "Application Data:Poser 7" or similar.  If you can't find that, just do a search of the Users folder for the libraryPrefs.xml (searching subfolders as well).
 -- Bjarne Stroustrup
TheBob ( ) posted Sun, 01 June 2008 at 9:38 PM
deleting the library didn't do anything
Morgano ( ) posted Sun, 01 June 2008 at 10:08 PM
Do you open Poser as "administrator"?
TheBob ( ) posted Sun, 01 June 2008 at 10:48 PM
yes of course..i set everything to full
Jules53757 ( ) posted Mon, 02 June 2008 at 1:46 AM
It also looks like you dont have Poser 7 SR2.1 installed.
Ulli
renderdog2000 ( ) posted Mon, 02 June 2008 at 2:07 AM
Schedule a checkdisk with automatic fixes enabled and reboot your machine.  It will take a while for checkdisk to run, but once it finishes defragement the harddrive.
-Never fear, RenderDog is near!  Oh wait, is that a chew toy?  Yup. ok, nevermind.. go back to fearing...
TheBob ( ) posted Mon, 02 June 2008 at 12:47 PM
i fixed it i just had to update poser..thanks all
renderdog2000 ( ) posted Mon, 02 June 2008 at 1:57 PM
Good deal, glad to hear it's working for you now :)
Jules53757 ( ) posted Mon, 02 June 2008 at 2:21 PM
You're wellcome.
Ulli
