Thu, Oct 10, 10:21 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 09 12:13 pm)
Subject: Ring around Irises... how do you remove them?
magnet ( ) posted Tue, 19 June 2001 at 10:35 PM ยท edited Thu, 10 October 2024 at 10:18 AM
Hi I am curious to know how you can remove the ring around Iris as in the picture. It looks as though I put contacts on her, but I assure you, I didn't ; )
Marque ( ) posted Tue, 19 June 2001 at 10:59 PM
Did you make sure that your texture map is loaded for all the parts of the eyes? I know that if you load in the eye maps and you miss the iris pupil or white it can do that. Marque
RealitysPoison ( ) posted Tue, 19 June 2001 at 11:01 PM
First of all, if you look at a real eye very closely, you will see the same thing. (Really, I promise) But, if you really don't want to see the cornea, the only thing I can think of is to go to your texture and resize the iris until it covers the next ring out (on the template, you will need to use it as a guide.) Hope that makes sense. I am tired and need sleep. Angela
magnet ( ) posted Tue, 19 June 2001 at 11:30 PM
Thanks that did the trick. The problem was the bump map I was using on the Iris. Problem solved... thank you all! magnet
melanie ( ) posted Wed, 20 June 2001 at 12:39 PM
Looks like contact lenses. :) Melanie
magnet ( ) posted Wed, 20 June 2001 at 1:00 PM
I thought so too.
