Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 3:32 pm)
The dials, if you point at one, hold the left mouse button, and move slowly left or right, tweak the parameter. It pops up and asks just what you want the number to be, when you double click on the actual number up and right of the dial and not drag the dial itself. Hence you have the choice. What I would like to know is how to delete some of the parameter dials themselves, for example if I dont need most of them (which I dont) and have to scroll thru 50 silly ones to get to 'bend'. Answers on a postcard please.
That sounds like you've got a mouse problem Marque. As in the pointer isn't pixel registering on screen properly, check the correct driver is loaded for the mouse. Other than that I don't have a clue what the problem is. The numerical dialogue requester shouldn't pop up unless you click on that section of the dial (as in ON the numbers). Just clicking the dial itself should allow you to use that function.
does anyone have any parameter settings for her,maybe i'm just slow but i cant seem to get her body types right[i.e.fairy]?also i just got poser 4,is there any way to stop those parameter boxes from popping up so damn much.would sure appreciate a reply.
