Mon, Feb 10, 1:15 PM CST
Subject: Free HDRI probes found
dyret ( ) posted Fri, 06 June 2008 at 6:24 AM · edited Thu, 16 January 2025 at 1:11 PM
dyret ( ) posted Fri, 06 June 2008 at 6:36 AM
ups... they don't seem to work 😠
dhama ( ) posted Fri, 06 June 2008 at 7:24 AM
Won't HDRshop convert them?
dyret ( ) posted Fri, 06 June 2008 at 7:41 AM
eh... maybe? the files are called hdr, but Bryce dont recognise them. I dont have HDRshop and now Bryce have totaly closed down th computer i use for it. So I'm not able to try it for a while.
dyret ( ) posted Fri, 06 June 2008 at 8:26 AM
I did a while ago find a few by looking in the Poser forum. I'm using them now. Try searching for HDRI over there. They seem to better than the once who came with Bryce.
dhama ( ) posted Fri, 06 June 2008 at 2:00 PM
Well I think they need to be light probe type, so if you do a search for 'lightprobe' specific HDR's then they should work with Bryce.
AgentSmith ( ) posted Fri, 06 June 2008 at 5:00 PM
Yeah, these aren't all that great to use in Bryce, they are in the wrong format and would need to be converted in HDRShop. But, even after converting, you are going to have that giant black band that they all have showing up in all your reflections and would look weird.
I used to have a link in the forum header that many links to Bryce usable hdri's, gone now.  ;o(
AS
dhama ( ) posted Fri, 06 June 2008 at 5:34 PM
Have you seen the Bryce 'BackRoom' HDR links? http://backroom.renderosity.com/~bryce/hdri/b6_hdri.htm
ThunderStone ( ) posted Fri, 06 June 2008 at 5:35 PM
AS
No AS... not gone, just moved to the back room section... here's the link : Bryce Backroom: Bryce links
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
AgentSmith ( ) posted Sat, 07 June 2008 at 2:49 AM · edited Sat, 07 June 2008 at 2:57 AM
Ah, there it be, thanks!  ;oD
Btw...The specific type of "format" to look for (the type of HDRI Bryce accepts) will be called either "Mirrored Ball" or "Angular Map". I've converted HDRI's from the "Latitude/Longitude" format to both Mirrored Ball and Angular Map, and Bryce accepted both.
"Light Probe" also works when searching for HDRI's, yet that was the term Debevec gave to his first HDRI's, before the various format/layouts existed, so keep that in mind.
AS
dyret ( ) posted Sat, 07 June 2008 at 4:50 AM
ok. hehe... just got exited a bit to soon. wow! 30 lights!!! and the extension was hdr so i thought these must work
FranOnTheEdge ( ) posted Sat, 14 June 2008 at 11:28 AM
I've got HDRShop, so how do you convert these into Bryce type .hdr's so you can use them?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
ThunderStone ( ) posted Sat, 14 June 2008 at 6:39 PM
Quote - I've got HDRShop, so how do you convert these into Bryce type .hdr's so you can use them?
Fran, this will help you out...
Converting HDRIs using HDRShop
Quest ( ) posted Sat, 14 June 2008 at 8:33 PM
Dyret, I believe HDRshop version 1 can be gotten free here [
http://projects.ict.usc.edu/graphics/HDRShop/](http://projects.ict.usc.edu/graphics/HDRShop/)
I got my copy free from a 3D mag a while back.
Curious, has anyone tried this freeware HDRI software [
http://www.hdrlabs.com/picturenaut/index.html](http://www.hdrlabs.com/picturenaut/index.html) ?
Checkout the features in the sidebar.
dyret ( ) posted Sun, 15 June 2008 at 3:57 AM
I got it a few days ago. So I'll probably get to try it by christmas. 2015 😄
