Mon, Feb 3, 2:26 AM CST
Subject: Question about Limit
smalll ( ) posted Tue, 10 June 2008 at 7:32 AM · edited Mon, 03 February 2025 at 1:45 AM
Hi, Ladies and Gentleman.
I'm studing Poser.
And I made a character.
It is very simple.
And I applied limit.
But, I does not work.
What's wrong with me?
Can you help me?
Please.
(Poser version is 7)
IsaoShi ( ) posted Tue, 10 June 2008 at 7:47 AM · edited Tue, 10 June 2008 at 7:49 AM
Just a thought - have you got the "Use limits" option ticked for the figure? It's on the Figure menu.
I would test it myself if I could, but I am at work!
wheatpenny ( ) posted Tue, 10 June 2008 at 7:51 AM
Site Admin
I removed the download link. You'll have to submit it to freestuff to go though to usual approval process. You can't link to it in a forum post, as that would circumvent the approval process
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
smalll ( ) posted Tue, 10 June 2008 at 9:17 AM
Thank you very much.
And I 'm so sorry....
IsaoShi ( ) posted Tue, 10 June 2008 at 2:38 PM
Hello smalll
Did you get your figure working properly?
Izi
Unicornst ( ) posted Tue, 10 June 2008 at 6:28 PM
Attached Link: Dr. Geep Studios
**There's a "Professor" and a "University" that can help you with pretty much anything you want to do about rigging ands making figures work.
His name is Dr. Geep and his "University" is the link at the top of this post.
Miss Nancy ( ) posted Tue, 10 June 2008 at 6:40 PM
wheat, I daresay smalll was uploading said link that others might download it
and fix its jps, and not as a freebie for general distribution.
markschum ( ) posted Tue, 10 June 2008 at 7:04 PM
limits will simply control how far the thing will bend , so you cant do unrealistric poses. Its only effective if you set limits on for the figure .   You need to set joint settings for each joint in the setup room I think. There are two sets of lines to set what is included and what excluded in the bend zone .
kuroyume0161 ( ) posted Tue, 10 June 2008 at 7:17 PM · edited Tue, 10 June 2008 at 7:17 PM
You can set joint settings in the Pose room simply by opening the Joint Editor and selecting the relevant body part.  Limits, of course, need to be set by double clicking the dial in the Parameter window.  The one problem is that Poser doesn't let you specify its little secret limits enabling value of 1 OR 4 so that Poser itself doesn't override the limit specifications.
Remember that Limits are ignored for body parts in an enabled IK chain!
 -- Bjarne Stroustrup
