Mon, Feb 3, 11:08 AM CST
Subject: pose folder
TIRROCCIA ( ) posted Tue, 17 June 2008 at 7:26 PM · edited Mon, 03 February 2025 at 7:57 AM
Is there a way to seperate the actual poses from the mats/morphs? i tried adding a folder in "pose" called "maps" it showed but all the stuff i put in it went poof. I have a large runtime now-30 gig. Can i seperate poses from map/morphs? is there any help out there?
markschum ( ) posted Tue, 17 June 2008 at 7:32 PM
I use a subfolder
runtime/libraries/pose/!!mats/whatever
runtime/libraries/pose/!!morphs/whatever
the !!  keeps them at the top of the folder list .
IsaoShi ( ) posted Tue, 17 June 2008 at 8:08 PM
All the stuff you put in it "went poof"?
I do the same as markschum, it works fine for me too.
But things going poof, well now... what help is there for that?
:O)
wdupre ( ) posted Tue, 17 June 2008 at 9:01 PM
everything going poof sounds like Poser 4 or Propack, which were limited to one layer of folders in each library, from poser 5 on you should have no problems with any amount of layers of subfolders.
grichter ( ) posted Wed, 18 June 2008 at 8:13 AM
Or if you move things around while in a given runtime, using P6 and above (no expereince prior to P6) reload the the runtime (faster) or change to a different runtime and then back to the runtime you are working in. It's the only way Poser will find things in an active runtime. (It has to reload it to know where you moved things)
Gary
