All the stuff you put in it "went poof"?
I do the same as markschum, it works fine for me too.
But things going poof, well now... what help is there for that?
:O)
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Or if you move things around while in a given runtime, using P6 and above (no expereince prior to P6) reload the the runtime (faster) or change to a different runtime and then back to the runtime you are working in. It's the only way Poser will find things in an active runtime. (It has to reload it to know where you moved things)
Gary
Is there a way to seperate the actual poses from the mats/morphs? i tried adding a folder in "pose" called "maps" it showed but all the stuff i put in it went poof. I have a large runtime now-30 gig. Can i seperate poses from map/morphs? is there any help out there?
