Can you post a screen capture of your material room with the new transmap attached?
say." - Ghandi
If you're talking about the document window and you have your display set to Texture Shaded, this is normal. The areas that are transparent will render just fine.
By changing the diffuse map and reloading the original, you remove the transmap settings and the areas won't render truly transparent.
What you can do is change the way your document window displays the model. Why don't you try using a different display style, like textured wireframe?
Hugz from Phoenix, USA
Victoria
heya!
poser pro, v4, various clothing:
i tried to redraw transparency map for a clothing piece. but after i connect transparency dial with that bitmap, all other clothing parts disappear as if set to "hide" and only one part stays and shows correct settings.
my bad or a feature? thanks in advance! :)
