Thu, Jan 9, 5:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 3:46 am)
Subject: cloth parts disappearing after dhanging transparency
aleks ( ) posted Fri, 20 June 2008 at 3:03 AM · edited Thu, 09 January 2025 at 5:27 PM
heya!
poser pro, v4, various clothing:
i tried to redraw  transparency map for a clothing piece. but after i connect transparency dial with that bitmap, all other clothing parts disappear as if set to "hide" and only one part stays and shows correct settings.
my bad or a feature? thanks in advance! :)
Acadia ( ) posted Fri, 20 June 2008 at 3:15 AM
Can you post a screen capture of your material room with the new transmap attached?
aleks ( ) posted Fri, 20 June 2008 at 4:17 AM
i don't do anything just set transparency to max and add a new map for transparency slot.
but i just found out, that if i load again the original map (change the diffuse map to anything else, then add original diffuse map) it works ok... well... poser... nuff said... ;)
Victoria_Lee ( ) posted Fri, 20 June 2008 at 8:45 AM
If you're talking about the document window and you have your display set to Texture Shaded, this is normal.  The areas that are transparent will render just fine.
By changing the diffuse map and reloading the original, you remove the transmap settings and the areas won't render truly transparent.
What you can do is change the way your document window displays the model.  Why don't you try using  a different display style, like textured wireframe?
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
aleks ( ) posted Fri, 20 June 2008 at 8:57 AM
it's an opengl issue or more likely the amateur-like implementation of it in poser. it all renders fine, it's just the preview (document window) that's buggy. the other preview-style (sreed or what's the name) looks cruder but it shows the changed transpareny map correctly.
