Thu, Jan 23, 11:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Problem about importing sound
smalll ( ) posted Sun, 22 June 2008 at 7:10 PM · edited Thu, 23 January 2025 at 11:21 PM
Hi.
I want to import sound into poser (version 7).
And I clicked menu like next
 File > Import > sound
It is done well.
And I make it a avi movie by click menu like next.
 Animation > Make movie
But there occurred a error message.
No movie is maked.
Any sound (wav file) is same.
Is it impossible?
Can you make it?
ockham ( ) posted Sun, 22 June 2008 at 9:52 PM
Normally this works OK, but Poser 7 sometimes has problems with making an AVI.
It's better to render the Movie to Separate Frames, and use an external
program, like VirtualDub, to combine the frames and the sound.
What was the error message?
My python page
My ShareCG freebies
smalll ( ) posted Mon, 23 June 2008 at 7:06 AM
Thanks to ockham.
I'll try.
Error message is korean.
So, I can't explain correctly.
Sorry....
Anyway, Thanks to you.
ockham ( ) posted Mon, 23 June 2008 at 8:11 AM
Could you copy and paste the error message?
Maybe I can translate it online.
My python page
My ShareCG freebies
Dale B ( ) posted Mon, 23 June 2008 at 4:42 PM
Hmm. The most common problem is that Poser's sound engine will only accept a single channel .wav file. If it a stereo, or Ghu forbid a 5:1 sound file, at best it will refuse to function and throw cryptic errors about unrecognized format. Just a plain old 8 bit mono .wav is all that works in the Poser app. The second most likely is that the codec being used isn't accepting the sound input. This could be for numerous issues, including only being a 'partial' codec (it was designed specifically to only decode; you have to buy the encoding part).
smalll ( ) posted Mon, 23 June 2008 at 6:21 PM
Thanks to Dale B.
You give me great help.
And Dear ockham.
You so kind to me.
I have no words to express my gratitude.
MaterialForge ( ) posted Mon, 23 June 2008 at 7:29 PM
Dale, have they removed support for stereo WAV in Poser 7? I haven't upgraded to it yet, but I've been able to import stereo files since version 3. That would be a step backwards in the audio department if they did that.
But like ockham said, it is best to combine the audio and animation in a video editing application.
operaguy ( ) posted Sun, 09 November 2008 at 6:15 PM
bump and scream
trying to import a .wav made in quicktime into PoserPro
Vista 64 bit home
"Poser does not support this audio format....etc"
I tried all settings out of Quicktime Pro on export including the lowest possible,
mono
8bit
8mhz
faster
do i have to convert my source .aiff into an avi and then to wave?
Any clues would be welcome.
::::: Opera :::::
MaterialForge ( ) posted Mon, 10 November 2008 at 8:52 AM
operaguy - try using these settings on the WAV file:
Mono
16-bit
44.1Khz sample rate
There are several variations of the .wav file format - the "Microsoft" flavor, Scott Studios .wav, and what is called "broadcast" .wav. If you can, I would recommend using another application to save the wav file, Audacity (free) is probably your best shot. I use the Microsoft .wav and it works fine. However, I am on XP, not Vista.
Hope this helps!
--Donnie
operaguy ( ) posted Mon, 10 November 2008 at 10:59 AM
thanks donnie i will try those ideas. gave up last night with one final scream!
operaguy ( ) posted Sat, 15 November 2008 at 8:09 PM · edited Sat, 15 November 2008 at 8:11 PM
I think it is a bug on either Vista or PoserPro. on Vista
I downloaded Audacity and opened the audio wav and saved it out to another file name as "microsoft wav" format. No matter what settings I used, including those indicated above by Donnie, I could not get PoserPro on VistaHome64 to let it in.
Note: audacity only goes down to 16, not 8bit.
Meanwhile, on another system running Poser 7 sr3 on XP 32, all of these wavs, including the ones I did not run thru audacity, loaded and played in Poser7.
I am very close to blowing Vista off that computer and installing XP pro 64.
::::: Opera :::::
MaterialForge ( ) posted Wed, 19 November 2008 at 3:26 PM
I only recently started using Vista on our home system, and for testing in my web development job - it's fine for general surfing, email, etc but I would not upgrade my audio and video production machines. Too many hoops to jump through, and I really don't like the constant popups, security notices, etc. Even after turning off all that, it's still a little paranoid.
I thought I was paranoid, but Vista is even more so... ;)
