You can click and drag in the animation graph window to select all but the first frame. Once selected click the delete key frame button. Now all you need to do is correctly set the first frame.
See http://www.philc.net/tutorial7.htm for a screen shot of the animation windows.
Hello
I have an animation and have had to lower the boxing ring to the floor. I did the first frame and it keeps popping back up so do I have to go thru it frame by frame and keyframe it. I tried using the graph but I cant get the line perfectly straight.
Thank you
