Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Is the problem with any character, or just V4?
I use the latest C6 standard and am not having any inj trouble, BUT DAZ changed V4 so that you have to load each and every morph.
If that is your problem, then look over at April YSH's website (She is the vendor responsible for so many of the fine hair models at DAZ). She has a freebie patch that loads all the morphs on V4 for you. You can preload a V4, save it as one of your objects in the browser, and be spared this trouble in the future.
If that is not the source of the trouble, I defer to the C6 pro folks.
I love C6, but I did feel a bit led on about the ease of using Poser content with Carrara. That said, I have developed a flow for working with the textures and characters. ALWAYS, the textures must be adjusted in the shader room. Almost always, some extraneous color has been overlaid on the texture map. This is an artifact that is poser's "fault". Other settings are reliably wrong too.
After I fix the shader tree, I save the "adjusted" shader in the C6 browser or a scene file, so I do not have to go through that again. Doing all this adjustment takes time and inhibits experimenting around. It's enough to drive a girl to procedural shaders!
I think I will put my V4 in an inner tube, floating on the ocean near one of Carrara's tropical islands and take a break!
Hi,
I have been out of the Carrara loop for awhile. I am using Carrara Pro with the latest 6.21 patch.
Everytime I try to load an inj it asks me to locate it manually. the version I was using 6 months ago did not do this. Is there a problem and if so is there a work around?
cheerio lululee
