Mon, Sep 9, 5:23 AM CDT
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 06 11:12 am)
Subject: problems conforming figures
nemirc ( ) posted Tue, 24 June 2008 at 6:32 PM · edited Sat, 03 August 2024 at 9:28 AM
Hello people.
I'm working on this figure set and I'm having the strangest problem. Whenever I hit the "conform" thing my shoes move like what you see on the first figure, even if the "centers and stuff" are correct.
nemirc
Renderosity Magazine Staff Writer
https://renderositymagazine.com/users/nemirc
https://about.me/aris3d/
nemirc ( ) posted Tue, 24 June 2008 at 6:33 PM
and when I hit the "zero figure" they move to the correct place... however this is extremely anoying... and I can't seem to find a way to fix that.
Do you happen to know what's causing this issue? :-/
nemirc
nruddock ( ) posted Tue, 24 June 2008 at 6:50 PM
IIRC, you need to make sure all rotations/translations are set to 0.0 and then memorise the (to  be conforming) figure before saving.
This is usually necessary because donor figure skeletons usually have small rotations applied to act as IK hints.
PhilC ( ) posted Tue, 24 June 2008 at 6:52 PM
After you zero the figure click the Poser menu Edit > Memorize > Figure, then resave to the library. I think your figure contains preset bends, this method will permanently remove them.
nemirc ( ) posted Tue, 24 June 2008 at 11:28 PM
Holy crap it works!
Thanks a lot. I will be eternally in debt with you people :)
nemirc
