Sat, Feb 8, 11:49 PM CST
Subject: Help with Mac sit files
cliss ( ) posted Thu, 21 June 2001 at 4:18 AM ยท edited Sat, 08 February 2025 at 11:30 PM
can anyone tell me how i can convert Mac sit poser files to pc readable files
Schlabber ( ) posted Thu, 21 June 2001 at 4:24 AM
You need the Aladdin Stuffit Expander to read sit-files http://download.cnet.com/downloads/0-10240-100-5180336.html in case it don't work search for Aladdin at www.shareware.com
cake1 ( ) posted Thu, 21 June 2001 at 9:49 AM
It depends of what's inside the .sit file. to create a zip file from it, use dropstuff (also from aladdin software) If you only want to read a mac fil on a pc use stuffit as Schlabber mentioned it, but be carefull cause the poser mac files are a bit different from poser pc files (no rsr files for example ). Hope it can help. Cecile
rtamesis ( ) posted Thu, 21 June 2001 at 11:39 AM
Attached Link: http://www.aladdinsys.com/expander/expander_win_login.html
Download Stuffit Expander for windows to decompress .sit files at http://www.aladdinsys.com/expander/expander_win_login.html
jschoen ( ) posted Thu, 21 June 2001 at 2:17 PM
As mentioned above, you will first need "Stuffit Expander". But also to point out: Unless you have a way of converting Mac files to PC or (I believe) Poser Pro Pack to read Mac files, it won't do you much good. You can however read several common files that may be included in a "sit' archive. I.E. jpegs and other image files. But you should have "Stuffit Expander" in your arsonal of must have apps anyway. James
flyerx ( ) posted Thu, 21 June 2001 at 8:08 PM
EditPad (do a web search to find it) converts between CR-LF (windows) and CR (mac) text files. Useful for cr2, pz2, and all poser text files. good luck, FlyerX
