Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
It depends of what's inside the .sit file. to create a zip file from it, use dropstuff (also from aladdin software) If you only want to read a mac fil on a pc use stuffit as Schlabber mentioned it, but be carefull cause the poser mac files are a bit different from poser pc files (no rsr files for example ). Hope it can help. Cecile
Attached Link: http://www.aladdinsys.com/expander/expander_win_login.html
Download Stuffit Expander for windows to decompress .sit files at http://www.aladdinsys.com/expander/expander_win_login.htmlAs mentioned above, you will first need "Stuffit Expander". But also to point out: Unless you have a way of converting Mac files to PC or (I believe) Poser Pro Pack to read Mac files, it won't do you much good. You can however read several common files that may be included in a "sit' archive. I.E. jpegs and other image files. But you should have "Stuffit Expander" in your arsonal of must have apps anyway. James
can anyone tell me how i can convert Mac sit poser files to pc readable files
