Sounds like a strange one. Don't suppose you have accidentally done "Lock Figure" from the Figure menu? Applied a "Lock Actors" pose, and forgot that you did that? Sorry, but those are the only two things I can think of if none of the dials work.
Do the Rotate and Translate dials still work? If it is only the FBM or morph dials that don't work, it could be more understandable.
I checked that and nothing like lock figure is on.
It get's even stranger. As an exampleI can't get the hand to grasp or un grasp, yet I'll bend a single finger and suddently the entire hand will move to the grasp setting. When I try to use the grasp dial again, nothing. Same thing with the neck. I'll put in a twist value, nothing, but move an eyeball and then suddenly the neck moves too.
I can only the lower portion of the body to rotate. The upper portion stays locked. It seems like it's everthign above the wast that is locked. All the morphs work fine, it's jsu movement and scale.
Very weird.
Thanks for the help
Yes, very weird. I have never heard of this one before. The only other thing I can think of is a memory issue, if something, either in Poser, or externally is hogging all the memory, that might cause the problem, but that is only a wild guess. Try closing any other applications that might be running in the background. If that does not work, try deleting everything from the scene except the figure and a couple of lights. If it's still the same, then I'm stumped, perhaps the pz3 got corrupted in some way.
Hello,
I just created a scene with V4 in P7 and have a problem. I use her all the time and have a large number of saved files with her. I in this scene she has complete locked up. I can't get any of her dials to do anything. They spin but no change to the figure takes place. I have opened other files and she behaves fine. Any ideas what could have caused this?
Thanks
Mark
