Sorry, I don't know the answer, but I'd like to know it also.
Food for thought.....
Mike's suggestion on Bucket size would be my first one too. But there may be other render setting changes that can give more leeway in the memory. what are your current settings.
The Reload textures may release them from memory I know it reloads the texture so any changes are displayed but does it unload unused ones? All the textures will still be listed in the Material room until it's closed down.
You can reduce the textures listed if you create a new scene to load when poser opens. If you delete casual Simon. In the preferences you can click the "set prefered state" button. Then this blank scene will be loaded each time poser starts wthout simons textures.
I get this a LOT too in p6. As far as I know there is no way to get rid of all those texture listings from what I've heard, it has to do with the sizes of the textures too. For instance, you use a v4 character that has a 4000x4000 texture, and all the clothes are 4000x4000 and the scene is also that size, kaboom, my poser chokes and dies. when I have to cancel I get back to the scene and all textures are gone from the way I currently view. I've resized some of the clothing that has large textures and that helped me. I also lowered my bucket size too down to like a 16? Plus there are times I render out pieces and put them together. I think vendors forget not everyone has mega computers. :(
You can try lowering your max texture size too, that may help a bit.
Sometimes I get that nasty "out of memory" message when trying to render in P7. As it turns out when I check how many textures are loaded into poser I find that in the drop down in materials it shows all the textures that I have been working with for the past hour or so, even the textures for characters that I have deleted out of the scene. Is there a way to get rid of all these extra textures without totally shutting down poser and starting over?
