Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 7:29 pm)
It is coming along. I do like the texture on the pants much better then the earlier WIP. There must be a difference in the gamma settings on our monitors. I saved the image and goosed the gamma up in a 2D paint program. The result was a very different picture. As displayed here, I can't see that the figure was doing some repairs to his arm and the increadable amount of detail in the background. Now I know the gamma on this monitor isn't spot on but the difference is to great for that to be the problem. It may be worthwhile to see where your's is set because right now the images are appearing darker then I'd think you want them to be.
The new texture for the pants make a big difference! I understand that you want the image dark, but I agree it might be a little to dark, on my monitor anyway. Of course, I have had the same problem in the past myself. I do most of my work at night, with out a light on and things look great. Look at it with the glare of sunlight on the screen and it looks to dark! Bushi, maybe you should close your shades and put out the lights and take another look? ;-) Seriously, the darker the image, the more pronounced the difference in viewing on various monitors with different gamma settings. It's tought to get results that are going to look good on a majority of monitors! I like high contrast images and this looks great. Under daylight, I agree that some areas are to dark and detail is being lost. Is the metal in the arm set to a high reflectivity? If not, upping it may bring out the detail with out having to brighten the entire image. If it's already high, you might want to have a lit object off camera which will reflect off the metal in the arm. I've positioned items off camera in some of my work before in order to provide a better reflection off a sword. It could work here. :-)
Well, I can tell you that on my monitor, even with the room lighted (small lamp behind and above my monitor) my blacks are black and not grey. My nvidia gamma controls tell me that my gamma is set at 1.10. I tried jacking it up to 1.6 and it opens up alot more details, but also makes his skin look washed out...Sheet..I don't know. It looks good on my monitor, what can I tell you. Thanks for the ideas...Actually most of the materials in his arm uses scarred or otherwise crumpled surfaces, that accordingly don't reflect much. Alot of anisotropic surfaces are also used, which further more cuts back on the visibility. I have tried numerous different lighting methods and styles and this current one seems to me to bring out the best mood. I'll see what I can do about picking out more details in his arm...Later Regards Ian
Attached Link: Street repairs...
Well, I changed some things per the suggestions of Fiontar and Bushi. I added some scars and some battledamage, plus some other paraphernalia. No postwork except the resize.Everything is done in texture. What do you think??? I am open for suggestions and criticism. Regards Ian
