Thu, Nov 28, 11:04 PM CST
Subject: Poser 7 Stopped Running
flibbits ( ) posted Fri, 04 July 2008 at 5:21 PM · edited Mon, 25 November 2024 at 7:51 AM
Today when I tried to run P7 it flashed to the gray screen as if it was about to start, then it disappeared.
The program will not run.
flibbits ( ) posted Fri, 04 July 2008 at 5:39 PM
Nothing in the event viewer.  Tried various compatibility modes.  No luck.
I'm going to try to reinstall, but wonder if I can safely restore my current runtime.
Peelo ( ) posted Fri, 04 July 2008 at 6:52 PM
If you can, backup your runtime before a new install.  Have you tried opening a pz3 file? Don't start p7, just open a pz3 file. That might get your p7 to work.
-Morbo will now introduce the candidates - Puny Human Number One, Puny Human Number Two, and Morbo's good friend Richard Nixon.
-Life can be hilariously cruel
flibbits ( ) posted Fri, 04 July 2008 at 7:12 PM
PZ3 is the same, a gray screen shows, the background window for Poser 7, then it goes away and nothing more happens.
Peelo ( ) posted Fri, 04 July 2008 at 7:29 PM
Well... That sucks big time. Something has gotten corrupted.  It's probably re-install time. Just be sure to backup your original runtime.  Copy your entire runtime to somewhere else. Then un-install and re-install. Or perhaps you could try and contact Smith Micro before unistalling p7. But it really sounds to me that something has gone really wrong and a fresh install of P7 is needed.
ockham ( ) posted Fri, 04 July 2008 at 8:36 PM
Be sure you re-install to a NEW folder, not to the default or original folder.
The installer often fails to overwrite corrupted DLLs.
My python page
My ShareCG freebies
flibbits ( ) posted Sat, 05 July 2008 at 12:39 AM
I installed to the original folder.  Everything works fine, I didn't even have to copy the backed up runtime.
Whatever the problem was, uninstalling and reinstalling in the same dir fixed it,
flibbits ( ) posted Sat, 05 July 2008 at 1:35 AM
I guess I spoke too soon.  Poser runs but won't load or render any of the old files.  The textures library is gone from the Poser 7 runtime, including from copies made a long time ago.  I just checked a copy on a DVD made 2 months ago, even the textures library there is gone.
Up until yesterday I had used figures from the main runtime, including their textures.  No idea where the textures directory went, or how it could have disappeared even from old copies.
snabald ( ) posted Sat, 05 July 2008 at 7:51 AM
I had a similar problem with another program and it turned out my hard drive was going bad, run chkdsk and see if it finds bad sectors.
flibbits ( ) posted Sat, 05 July 2008 at 11:33 AM
I'll do that, but it doesn't explain why the textures dir disappeared on DVDs and Hard Drives not connected to the PC, in storage.
flibbits ( ) posted Sat, 05 July 2008 at 6:42 PM
I have Michael 3 completely installed in a external runtime.  I've loaded M3 from that runtime forever.  Apparently it uses the textures from the main runtime, because with them gone the M3 takes forever to render and/or load.
At least I can copy those textures over, but the thing is all the freebies I had installed.  It's going to be a long time downloading stuff to find the textures.
ARGH.
Peelo ( ) posted Sat, 05 July 2008 at 10:41 PM
I feel your pain. My entire poser runtime went kaput 3 weeks a go. Everything I had ever done with poser in the last (oh lets say) 8 years, was washed away. Hard drive got a little bit destroyed.
seattletim ( ) posted Sun, 13 July 2008 at 10:28 AM
Could be needing a restart? Isn't Poser a memory hog? Maybe shut down and restart to fix it. . . I am wondering if this will work for you.
