If you can, backup your runtime before a new install. Have you tried opening a pz3 file? Don't start p7, just open a pz3 file. That might get your p7 to work.
-Morbo will now introduce the candidates - Puny Human Number One,
Puny Human Number Two, and Morbo's good friend Richard Nixon.
-Life can be hilariously cruel
Well... That sucks big time. Something has gotten corrupted. It's probably re-install time. Just be sure to backup your original runtime. Copy your entire runtime to somewhere else. Then un-install and re-install. Or perhaps you could try and contact Smith Micro before unistalling p7. But it really sounds to me that something has gone really wrong and a fresh install of P7 is needed.
Be sure you re-install to a NEW folder, not to the default or original folder.
The installer often fails to overwrite corrupted DLLs.
My python page
My ShareCG freebies
I guess I spoke too soon. Poser runs but won't load or render any of the old files. The textures library is gone from the Poser 7 runtime, including from copies made a long time ago. I just checked a copy on a DVD made 2 months ago, even the textures library there is gone.
Up until yesterday I had used figures from the main runtime, including their textures. No idea where the textures directory went, or how it could have disappeared even from old copies.
I have Michael 3 completely installed in a external runtime. I've loaded M3 from that runtime forever. Apparently it uses the textures from the main runtime, because with them gone the M3 takes forever to render and/or load.
At least I can copy those textures over, but the thing is all the freebies I had installed. It's going to be a long time downloading stuff to find the textures.
ARGH.
I feel your pain. My entire poser runtime went kaput 3 weeks a go. Everything I had ever done with poser in the last (oh lets say) 8 years, was washed away. Hard drive got a little bit destroyed.
Today when I tried to run P7 it flashed to the gray screen as if it was about to start, then it disappeared.
The program will not run.
