Mon, Jan 27, 8:06 PM CST
Subject: vista home prem . vue 6 xStream.eon crashing
shadeus ( ) posted Sat, 05 July 2008 at 8:42 PM · edited Mon, 27 January 2025 at 8:04 PM
as stated by subject. any help? my version is 6.5 build 291733
gillbrooks ( ) posted Sun, 06 July 2008 at 1:41 PM
Can't offer any help but if it's any consolation, I get the same thing but Vue6Infinite.eon stops working on my laptop.  Also occasionally, biosphere.eon stops working too.    That's on Vista home premium.  Uusually happens after the 'video driver has crashed and recovered'
Gill
shadeus ( ) posted Thu, 10 July 2008 at 12:05 AM
Bump
anyonehave any Solutions? it makes it very difficult to do anything
Jonj1611 ( ) posted Thu, 10 July 2008 at 2:58 AM
Some more information would be handy, for instance operating system, Vue version, what steps you have taken to rectify the problem already etc
Jon
DA Portfolio - http://jonj1611.daportfolio.com/
shadeus ( ) posted Thu, 10 July 2008 at 9:52 AM
uh its all there, in the subject it says VISTA HOME PREMIUM and in the body it says version is xStream 6.5 build 291733.
i have tried reinstalling over and over and it doesn't fix it
Jonj1611 ( ) posted Thu, 10 July 2008 at 10:55 AM
Well good luck with it, I am sure someone can help you, might be helpful to know if it was 32 bit or 64 bit as driver issues could be at play.
Jon
shadeus ( ) posted Thu, 10 July 2008 at 11:14 AM · edited Thu, 10 July 2008 at 11:14 AM
its 32 bit. i dont know if there is any other info that could help
Jonj1611 ( ) posted Thu, 10 July 2008 at 11:29 AM
Ok, some random suggestions :-
Do you have a graphics tablet? If so unplug it and uninstall drivers, see if Vue works then.
Are you running Vue as adminstrator? If not run it as administrator and see if that fixes it.
Are you trying to use any Cornucopia content when crash occurs? If so remove the content and redownload, then try again.
Ok, maybe obvious this one, but do you have the latest graphics drivers installed? If not install them, and try again.
Jon
Peggy_Walters ( ) posted Thu, 10 July 2008 at 11:29 AM
There is a new patch for xStream - Version 6.60 - Build 292711.  That may help.
Also for Vista, make sure you are running Vue as adminstrator.  It's not enough to give it admin rights, you must right-click on the exe icon and select Run as Adminstrator.
LVS - Where Learning is Fun!
shadeus ( ) posted Thu, 10 July 2008 at 12:05 PM
i am able to enable "run as administer" on the shortcut but not on the actual exe. i am loged in as administer.
shadeus ( ) posted Thu, 10 July 2008 at 12:39 PM
i was using a tablet and uninstalled it but it still does it.
MarkHirst ( ) posted Thu, 10 July 2008 at 2:15 PM
I assume you've turned off Open GL and tried running in safe mode to see if that helps?
I seem to remember there was a hoopla about OpenGL support in Vista, something about layering it over DirectX.
Related, you might want to check for updated video drivers. I always go for the WHQL certified drivers where ever possible.
www.CambrianMoons.com
shadeus ( ) posted Thu, 10 July 2008 at 11:15 PM
turned off openGL and have the latest drivers 1.75 for the duel 8800 gts 512
still problems :(
Jonj1611 ( ) posted Fri, 11 July 2008 at 2:29 AM
Have you contacted E-On Technical Support about this?
They would be the best people to ask and sometimes can provide certain versions of Vue that may trace the fault.
Jon
krickerd ( ) posted Fri, 18 July 2008 at 12:26 AM
Yeah folks are complaining about this on Eon's forums including me.  I now have a "lemon" file (scene that will not load - crashes), didn't feel right about calling it a boat anchor since it's software.  I'm really not happy about paying $750 for a program that is crashing more than any other software I own!
Am using Vista Home Premium with SP1
Vue Infinite Version 6.60-04
Xpleet ( ) posted Fri, 18 July 2008 at 3:06 PM
i have the annoying proengine.eon error whenever i try to run a newer patch other than 6.5
