On the lower right hand side you have these little dots called pose dots , it also has camera dots and UI dots. After you set your workspace up you can click a UI dot , this will put that set up in memory , then when you have this problem , all you have to do is click that dot that you saved, it will bring your workspace back to the way you like it. I am so happy since I figured this out , cause I too got really upset when poser did that to me, but sometimes the cure is right there and we just have to be lead to it :-) Hope this helps :-)
heh, yeah thats what mine did , glad you found you a dot , I hadnt thought to offer one , maybe you could email support or one of the other branches at CL to see if they would add it to the buglist, I doubt that every problem that goes on here gets noticed or brung to their attention. And using the dot will also help when you boot poser and have no workspace at all , that seems to be my latest bug. Glad youre getting it fixed :-)
heyas; there's a bug in poser where it won't remember your screen layout, that has to do with the stupid poser shortcut in windoze. delete the shortcut and re-create it, and it SHOULD work okay. (if this is that problem.) if you're on a mac, i have no idea what the problem is. :) wait, is this pro pack? that background wireframe isn't in poser 4. :/ i dunno what it is, then. maybe poser's trying to load a 4 window view??
I had this problem not long ago. Curious Labs provided the answer that worked: "Type on the keyboard "PO2" and after the interface reverts to the P2 interface, type "PO3" to return.........you may have to delete your Poser4/Runtime/prefs/poser.ini" This is assuming that you have ProPack installed. I also had some luck in clicking on the Setup tab and back again. See thread on "Spiderman"
Gordon
This is what happened to me when I insalled the 4.0.3 update. I ended up uninstalling everything and reinstalling Poser, then I copied the preferredstate.pz3 file from Prefs folder somewhere temporarily. After installing the update again, I just replaced the preferredstate.pz3 file in Prefs from the old version and everything has remained in place since. Give that a try. Melanie
The UI dots were only temporary for me. It still didn't fix the problem. I had to click the dot every time I opened Poser because it kept messing up. I didn't want to be bothered with that every time. Replacing the preferred state pz3 fixed it permanently so I didn't have to use the dot. It's never happened since. Melanie
I opened up poser this morning and my document window is on the upper left of my screen. I cant figure out a way to get it to the middle where it belongs, I even tried going to a higher resolution (which works temporarily)and moving it but when I return to 1024x768 its in the upper left corner again. Loading the factory state for the interface/document doesnt work either. What the hell? Goddamnit this is the third time this has happened, and I've heard it happen to other people as well. Instead of planning complex software protection schemes curious labs should get their asses working on bugs like this that have plagued Poser from the start. Seeing as I cant run my computer in 1280x1024 resolution permanently, (unless someone knows a solution to this bug) I guess I'm going to have to reinstall Poser AGAIN.
