Sat, Jan 18, 5:10 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 10:25 am)
Subject: PropViewer 2 is comming
kawecki ( ) posted Tue, 08 July 2008 at 8:44 AM · edited Sat, 18 January 2025 at 5:07 PM
PropViewer is an application that allow you to view obj, 3ds, dxf and Poser files.
What's new in bersion 2
  • Now you can view hr2 and cr2 files too.
      All the pp2, hr2 and cr2 must have internal geometry as it was in version #1, if you want to see
      files that use external geometry look at the obj file instead.
  • You are able to view dynamic hair in hr2, pp2 or obj files.
  • Read 3ds files in a correct way, something that Posers not always do.
  • DXF files continue to be limited to 3DFACE entities.
  • You can export as obj or as pp2, in other words PropViewer 2 can be used as a format    converter (obj, 3ds, dxf, pp2, hr2 and cr2 to obj or pp2)
  • You can save what you see as image, for the moment only as bmp.
  • PropViewer 2 fix corrupted meshes removing corrupted faces (a traingle with two sides, with duplicated vertices, etc).
  • If a mesh has no texture mapping PropViwer 2 create texture coordinates in an automatic way.
     Not always the texturing will be good, but is better than nothing.
Stupidity also evolves!
GKDantas ( ) posted Tue, 08 July 2008 at 11:10 AM
This looks cool... but where is the link? I already dont know the older versions...
Follow me at euQfiz Digital
jonnybode ( ) posted Wed, 09 July 2008 at 4:54 AM
Hi Kawecki!
I found a version 2.0  of this utility in your frestuff, tested it and it was really nice.
It seems to be from 2002-06-01 so im very curious about your new version.
Best regards / Jonny
kawecki ( ) posted Wed, 09 July 2008 at 6:13 AM
Is version 2? Damn, I forgot.
Well then I'm doing version 3 now.
jonnybode ( ) posted Wed, 09 July 2008 at 8:10 AM
Maybe you can call it PropViewer 2 Pro?
Regards / Jonny
EnglishBob ( ) posted Wed, 09 July 2008 at 10:36 AM
Excellent news, looking forward to this. I use Prop Viewer regularly, and these are exactly the sorts of enhancements that will make it even more useful. Mine is version 2.0, as well - it was released some time ago, so you can be forgiven for forgetting. :)
nickedshield ( ) posted Wed, 09 July 2008 at 10:48 AM
That's the same version I get.
Marque ( ) posted Wed, 09 July 2008 at 11:24 AM
Is it free?
kawecki ( ) posted Wed, 09 July 2008 at 2:11 PM
Quote - Is it free?
YES.
I don't keep track of the versions, is only a war name even in my computer it has a different name and what exist is only the latest version.
In the present moment I am working in two projects at the same time, the PropViewer and the dynamic hair converter and both are the same thing. I enhance one part and the other part.
I started with the dynamic hair converter so I have to change the structure of my nucleous to support lines and the chnages propagated to other modulesm nodules that are not needed for hair, but I chnaged and improved to be compatible with the new structure and these chnages I have to propagate to other software that I use for creating models.
When all is ready I shall sepparate the PropViewer and the hair converter into two different entities.
