DAZ|Studio F.A.Q (Last Updated: 2025 Feb 02 12:10 am)
4000 pixels is about as large as I have had the need to go, but it works for me.
(keep in mind that I am still on 1.8, so if the tabs/dialogs are different I apologize...)
At the top of the screen/window there is a drop-down for "render," in that drop down is render settings. Open this dialog. Set an appropriate ratio/aspect (square, 3:4, etc..), once this is chosen enter the desired size in pixels. I suggest choosing to render to file, in the options further down, instead of rendering to another window or what have you. I don't know if that last part might have anything to do with your situation, or not, but I know it was my problem getting full screen size, or larger, renders back when I started out in Studio.
Hope this helps, or that if it is a bit different in the current versions that someone will come in behind me and and correct it. :)
I've seen some people's DAZ Studio renders posted as fairly large pictures, but for me, I can't find a setting that outputs a large picture larger than the 700 pixel range or so. Setting the pixels to the max of 10,000 doesn't seem to affect the actual rendered picture's size, so I have to go into GIMP 2 and make it larger. Then, of course, you risk some definition loss. Sharpening helps, but I prefer not to use it.
Is there any way to get bigger pictures in DAZ without increasing them in post work?
Thanks,
