Sat, Jan 11, 2:40 AM CST
Subject: .pz3 setting
santicor ( ) posted Fri, 11 July 2008 at 12:03 PM · edited Sat, 11 January 2025 at 1:41 AM
sorry about this:
I have a .pz3  file , it's a set ( a room with some tables chairs, walls, floor, etc.) that  I want to use for a scene ( in Poser7)
How do I load it in?
The FILE - IMPORT  method  does not seem to offer me the right option.
Should I place the .pz3  in the library? If so, what should the path under RUNTIME  be?
Thanks
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
nickedshield ( ) posted Fri, 11 July 2008 at 12:15 PM · edited Fri, 11 July 2008 at 12:17 PM
Under the File Command: Open Locate the folder containing the pz3 the open option Poser Scene File(Pz3). Must learn to type faster:) Xposted with acadia.
Acadia ( ) posted Fri, 11 July 2008 at 12:15 PM · edited Fri, 11 July 2008 at 12:16 PM
File and "Open" will open the .pz3 file for you  :)
You can store your .pz3 files anywhere you want, even on an external hard drive.  Just simply using the browse feature in the "open" window to locate it.
Be prepared to wait while it opens though. Sometimes depending on how large the .pz3 file is it can take a few minutes to open.
Realmling ( ) posted Fri, 11 July 2008 at 12:15 PM · edited Fri, 11 July 2008 at 12:17 PM
a pz3 is a saved poser scene file, all you need to do is launch Poser, go to File --> Open -->{browse to file location}
You can store the pz3 file anywhere on your computer that you wish.
(ya'll type faster than me...) :laugh:
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser goodies and so much more!
Acadia ( ) posted Fri, 11 July 2008 at 12:16 PM · edited Fri, 11 July 2008 at 12:17 PM
hehe, triple cross post :)
We're such a helpful bunch!
nruddock ( ) posted Fri, 11 July 2008 at 12:40 PM
Use either File | Open... or if you want to merge the contents with an existing scene use File | Import | Poser Document/Prop...
santicor ( ) posted Fri, 11 July 2008 at 1:06 PM
FILE - OPEN,  not  FILE- IMPORT   ........Duh. !!!
I need to poke around more before asking questions, but I am usually away from P7 and sitting at my office!
Thanks
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
IsaoShi ( ) posted Fri, 11 July 2008 at 1:42 PM
At the office? Away from P7?? You mean doing WORK stuff???
For goodness' sake get your priorities right, santino.
Get Poser Pro on your office PC.
:O)
markschum ( ) posted Fri, 11 July 2008 at 2:40 PM
:woot: late again :)
there is a poser manual in pdf format in the poser folder .    program files/e-frontier/poser 7 .
I think you can access it from the HELP menu in Poser.
santicor ( ) posted Fri, 11 July 2008 at 3:16 PM
I know but it is a horrible manual,  the P7 reference guide is not much better. But you know this from a long time ago when you were a newbie.... ;-)
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
Philywebrider ( ) posted Mon, 04 August 2008 at 11:32 PM
I down loaded a pz3 'light setting' file. I want to put it in a library file. I tried putting it in the libraries 'ligfht file, but it doesn't show up.on the listing. What am I doing wrong? I tried Dr Geep's for a "where the files go listing" but I couldn't find it on the  site,. I'm sure it's there, but I can't find it.
Can any body hep a dummy?
FrankT ( ) posted Tue, 05 August 2008 at 2:33 AM
You won't be able to put it in the libraries.  A pz3 file is a poser scene so you'll have to load it from the file -> open or file -> merge menus.
You can put the pz3 pretty much anywhere so long as you remember where you put it
My Freebies
Buy stuff on RedBubble
raven ( ) posted Tue, 05 August 2008 at 10:35 AM
If it is one of your .pz3s that you created, then File->Open would be fine, as it should open in the interface state that you use.
If it is a .pz3 created by someone else, then I would File->Import Poser Document/Prop otherwise the display will change to the settings of whoever saved it. For example, I run my screen @ 1920x1200, if you open a .pz3 from me I've a pretty good feeling it would probably mess up your Poser display, however, if you were to import it, it would be made to fit to your settings. At least that's my experience of 3rd party .pz3 files.
Nance ( ) posted Tue, 05 August 2008 at 11:21 PM · edited Tue, 05 August 2008 at 11:31 PM
If you want to load the scene from your library to be able to add it to an open scene, another approach is to just parent everything, (figures, props, lights, whatever you want in the scene) to an invisible or null figure.   This null figure can then be saved to, and reloaded from, the Character library with all the stuff attached.   (Also allows the normal benefits of parenting such as being able to move the whole room at once.)
If there is a ton of stuff to parent, it's faster to drag-&-drop them in the Hierarchy Editor window.
...also, one of the smart guys here recently posted a mini-tute on using a pz2 file to load a pz3.   Got it bookmarked somewhere, so if that sounds more like what you were wanting to do, ask and we'll find it again.   This works similar to FILE>IMPORT, just done from a library so you don't have to remember the path to the scene.
Nance ( ) posted Wed, 06 August 2008 at 10:32 AM
Attached Link: Loading a pz3 from Library menu
& here's that thread by albertdelfosse in which LostinSpaceman gives some simple code for using a .pp2 to load a pz3:
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=3268129&ebot_calc_page#message_3268129
