Oh - I thought you made one.
The skin shader is the material (Material Room configuraton) that defines the skin. Some shaders are simple and don't need the advanced material room (nodes). Others are so complicated they use hundreds of nodes to achieve effects.
You didn't show a render, or your render settings, or your shader, or your lights, so I need to figure out what is causing this "fade" you asked about. If you did something wrong in the shader, you could make any material fade to black or white or whatever. I can read shaders like English, so that's where I wanted to start, because that's the first place people go wrong.
The second place people go wrong is lights. I was going to ask about those, if and only if I saw that your shader was good.
Render settings (which you asked for) don't usually affect how things are colored or lit, such that they would appear "faded". Only shader or lights would do that.
Please can somebody tell me what are the best settings to render so the textures and make-up won't fade? I have tried everything... but somehow their is allways something not right!!
I would appreciate any help very much!!
