Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
No it isn't already like this. Maybe in one place, but that's not the place it is talking about.
Look at the error it is showing you what line exactly:
File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedUnimeshRealismKit.py", line 1096, in init
Label(self.StatusFrame, text='Selected Figure : ').grid(row=0, col=0, sticky="e")
It says right there, line 1096, col=0
There are typically many lines with row and col. You'll need to change
all of them. If you have a good word processor, you should be able
to do a "search and replace all" command, to change all
col=
to
column=
My python page
My ShareCG freebies
Attached Link: http://physicalc-software.com/forum/viewtopic.php?t=137
> Quote - ... I believe the latest have been updated.Post by the author detailing which scripts have been updated.
I just upgraded my Poser7 to SR3 and, yesterday, while trying to use OclusionMaster in a render I got this error in the script screen:
Traceback (most recent call last):
File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedOcclusionMaster.py", line 338, in ?
MatDlg = MaterialsDlg(tk)
File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedOcclusionMaster.py", line 70, in init
Label(self.HelpFrame, text='HELP', font=f).grid(row=0, col=0,sticky="w")
File "D:E frontierPoser 7RuntimePythonliblib-tkTkinter.py", line 1790, in grid_configure
self.tk.call(
_tkinter.TclError: ambiguous option "-col": must be -column, -columnspan, -in, -ipadx, -ipady, -padx, -pady, -row, -rowspan, or -sticky
I tryied changing the script code, bud as looking trough the code I saw everything was as it should be, so I got confused...
UnimeshRealismkit is also doing a similar error:
File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedUnimeshRealismKit.py", line 1566, in ?
SkinShader = SkinShaderDlg(tk)
self.tk.call(
Actually they are kinda the same, but better put more than less info in the post.
I hope someone helps me, Altough I have V4Realism Kit I still use Aiko3 a lot in my renders, and Occlusion Master is already a great tool itself, I don't want to loose them.
Thanks already.
